Cam Position Sensor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by niit_train, Jan 3, 2018.
  1. Jan 3, 2018 at 1:08 PM
    niit_train
    niit_train [OP] Well-Known Member
    WV
    06 Double Cab
    No mods, just extra accessories. Realtree bug shield, vent visors, and a custom Realtree Hunter 4X4 Bully
    I have searched and read about the cam position sensor. Here’s what I have... 2006 4.0 with 106,000 miles. My oil light came on yesterday evening and then this morning, the check engine light came on. I took it to Autozone for a test and their machine said a bad cam
    Position sensor. I am pretty much a shade tree mechanic but am by no means intimidated by many part swaps. My concern is are the 2 lights being on within a few hours related? Oil level is fine. I don’t run the truck that hard and only put 10,500 miles on it last year. What are your all opinions on this?
  2. Jan 3, 2018 at 1:26 PM
    Clearwater Bill
    Billy
    Largo Florida
    The oil light is not level related, it's pressure related.
    If the oil is so low there's no pressure, that's a problem.
    I've seen them come on from a bad sender or a dirty sender connection.
    Was that light still on to and from Autozone?
    And what was the specific code for the CPS ?
  3. Jan 3, 2018 at 1:34 PM
    niit_train
    WV
    06 Double Cab
    Oil level is fine. It is at the top dimple of the dip stick. He didn’t give me the actual code number so I’m unsure of it. The oil light doesn’t come in until after 3/4 of a mile or so. The check engine light has not went off.
  4. Jan 3, 2018 at 1:37 PM
    Clearwater Bill
    Billy
    Largo Florida
    CEL on steady? Notice any drivability issues?
  5. Jan 3, 2018 at 1:44 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    sounds like low oil pressure causing a CPS code to be thrown cus VVTI is outside of specified ranges. Id make sure oil pressure is good before driving much more!
  6. Jan 3, 2018 at 2:43 PM
    niit_train
    WV
    06 Double Cab
    It’s parked for now. This is the info I’m wanting. I wondered if the oil pressure being low would cause other issues. So for now I need to check oil pressure before going any further?
  7. Jan 3, 2018 at 3:00 PM
    niit_train
    WV
    06 Double Cab
    Yes it is on steady.
  8. Jan 3, 2018 at 3:05 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You're on the right track. Oil level/condition/pressure is critical for valve train operation
  9. Jan 4, 2018 at 8:30 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I agree oil pressure problem. Do not continue driving this as if the oil pressure is low you will wipe out the engine.
  10. Jan 4, 2018 at 10:26 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Always ask them for the DTC(s). Their interpretation is worth 1/10th or less of the actual code. Better yet buy a cheap code reader; or one of the cheap ELM327 clones from eBay with a bluetooth interface and one of the various OBDII apps onto your phone (I like Torque or OBD Fusion)--then DIY...
  11. Jan 4, 2018 at 10:35 AM
    niit_train
    WV
    06 Double Cab
    It’s been sitting for now. I have a guava and will check the pressure this evening. Temps have been below 0 here so there may be other factors too. I need to get it inside a warm garage to really figure out what’s going on.
  12. Jan 4, 2018 at 11:00 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Maybe somehow the wrong oil got put in, too thick? If it's super cold it could have a hard time sucking it up the pickup tube in the oil pan..
  13. Jan 4, 2018 at 2:05 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I don't know what good a guava is going to do?
    A pressure gauge may help.
  14. Jan 4, 2018 at 4:55 PM
    niit_train
    WV
    06 Double Cab
    LMAO! That’s great!
  15. Jan 5, 2018 at 8:10 PM
    niit_train
    WV
    06 Double Cab
    Wind chill of -2 here so it’s still too cold to work outside. Truck is still parked for now. I’ve been searching endlessly on what all this could be and have found that it could also be a faulty oil control valve (variable valve timing solenoid). These options seem way better than the oil pump. Lol! I’m getting excited knowing that once I get started, I may be on the right track before I even start. Any of you have an opinion on this being part of the problem?
  16. Jan 5, 2018 at 8:20 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The reason your oil pump is kinda a concern is because in your original post you said you saw the oil (red oil can) light come on. That's not a good sign for the health of the oil pump or the pickup tube. The cam code is a p0340? That is a cam gear that is mechanically not lined up with the crank gear. If the timing chain tensioner(s) lost oil pressure momentarily it could let the chain slip a tooth or two, resulting in the code.
    In short you may have both a oil pressure issue and (now) a chain/timing issue.
    If you simply had the cam code (by itself) and never saw the oil light then i would be more comfortable "throwing" some solenoids at it
  17. Jan 7, 2018 at 1:32 PM
    niit_train
    WV
    06 Double Cab
    So I found the oil pressure switch to not be reading correctly. Replaced it and the oil light went off for now... just running in the driveway... I also bought an Actron OBD II Pocket Scanner. Codes thatit is showing are P0022, twice, P0441 and P0455. I’m researching all of those now. I erased those codes to see if they pop back up while running the truck. Hopefully I can get to the bottom of this. Lol!
  18. Jan 7, 2018 at 4:09 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    P0022
    desc: Camshaft Position "A" - Timing Over-Retarded (Bank 2)
    possible causes:
    - Valve timing
    - Oil control valve (OCV)
    - OCV filter
    - Camshaft timing gear assembly
    - ECM
    I'd check simple stuff first; OCV filter and OCV valve, both are not unusual issues.
    P0441
    desc: Evaporative Emission Control System Incorrect Purge Flow
    possible causes:
    - Purge VSV
    - Connector/wire harness (Purge VSV - ECM)
    - ECM
    - Canister pump module
    - Leakage from EVAP system
    - Leakage from EVAP line (Purge VSV - Intake manifold)
    P0455
    desc: Evaporative Emission Control System Leak Detected (Gross Leak)
    possible causes:
    - Fuel cap (loose)
    - Leakage from EVAP line (Canister - Fuel tank)
    - Leakage from EVAP line (Purge VSV - Canister)
    - Leakage from fuel tank
    - Leakage from canister
    These two are obviously related, again check easy stuff; fuel cap gasket, EVAP lines--in common in additional to leaks is the EVAP canister pump module...
  19. Jan 7, 2018 at 4:15 PM
    niit_train
    WV
    06 Double Cab
    Thanks for the info! Helps a lot
  20. Jan 7, 2018 at 5:54 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    Do you know what grade oil is in the engine? Kind of a long shot, however if 10W-xx or heavier it could interfere with the OCV function at near 0°F temps...
