Cam shaft issue?
Discussion in '1st Gen. Tacomas (1995-2004)' started by kph8720, Jul 15, 2025.
  1. Jul 15, 2025 at 6:05 PM
    kph8720
    kph8720 [OP] New Member
    Kevin
    96 Extended Cab w/ 2.7 Auto
    Initial issue was loss of power steering and then found that none of the belts were spinning. Ruled out anything being seized and found that cam shaft isn’t spinning. Engine starts fine though. Any thought on what’s going on?
  2. Jul 15, 2025 at 6:08 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Camshaft is definitely spinning if engine starts at all. You sure you’re not thinking of another term?
    t0p_d0g and TnShooter like this.
  3. Jul 15, 2025 at 6:11 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Crank shaft pulley bad? Is it spinning? If so you have some accessory or idler seized, If not, maybe the crank pulley separated. Hopefully it didn't spin on the crankshaft.
    Digiratus and t0p_d0g like this.
  4. Jul 15, 2025 at 7:45 PM
    kph8720
    Kevin
    Crankshaft is term I was looking for. Not camshaft.
  5. Jul 15, 2025 at 7:49 PM
    kph8720
    Kevin
    I pulled all the belts to make sure it wasn’t something like power steering pump or ac that was seized. Still the same issue. Sounds like I should look into the crankshaft pulley.
  6. Jul 16, 2025 at 12:16 PM
    Glamisman
    Glamisman Well-Known Member
    My strong advice is that if you are not 1000% sure in your mechanical abilities, let the Toyota Dealer replace the crankshaft pulley. There is a horror story on this forum where the crank pulley was replaced at a shop, not a dealer, and they are having to put a motor in the truck. I say Toyota Dealer because if they make a mistake, they have the finacial ability to fix or replace it.
    ControlCar likes this.
  7. Jul 16, 2025 at 1:11 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I think you need to take some steps back and make sure you are using the correct terminology for the problem you are trying to fix. Either way, your engine wont run if the crankshaft or a camshaft is seized. I think it would be technically possible for the crankshaft pully to not rotate with the crankshaft, but that some pretty serious implications.
  8. Jul 16, 2025 at 3:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    How many miles are on the truck?
    Is the inner portion of the crankshaft pulley spinning when the engine is running?
