Cam Shaft needed for a 6 psi supercharger 2012 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pennykiller, Nov 10, 2022.
  1. Nov 10, 2022 at 4:03 PM
    pennykiller
    pennykiller [OP] Member
    I plan on adding a supercharger to my truck and wanted to change out the cam but idk where to find a cam for my truck after it is supercharged. the supercharger is rated up to 6 psi so a 6 - 10 psi cam I would like to have if later want to change the psi of the supercharger.
  2. Nov 10, 2022 at 4:20 PM
    pennykiller
    no because I haven't found a company that makes after market cams for my truck
  3. Nov 10, 2022 at 4:22 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Kelford
    JuanitoBonito likes this.
  4. Nov 10, 2022 at 4:22 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  5. Nov 10, 2022 at 4:26 PM
    pennykiller
    so Kelford does have my engine in there selection i have the 1GR-FE v6 4.0L Tacoma
  6. Nov 10, 2022 at 4:26 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Why are you wanting to change the cams? The 4.0 can be supercharged with no modifications other than injectors and tuning, Toyota even made a supercharger specifically for it that was available as a dealer addon or through TRD.
    Haven't heard of anyone changing cams unless they were planning on doing a full build for racing or something like that.
    There is a member on here that makes -3 degree exhaust cam gears that help out with power and fuel economy but thats as far as most people go regarding cams.
  7. Nov 10, 2022 at 4:31 PM
    pennykiller
    there are not alot of people that do the cam swap but the toyota got rid of there dealer supercharger some else makes it. i want to make 370-400 hp with 500ft/lbs of torque with this build.
  8. Nov 10, 2022 at 4:34 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ah ok that's beyond me but good luck:thumbsup:
    Check with the guys in the performance and tuning section, there's quite a few smart people that know alot about that kinda stuff that hang out over there.
  9. Nov 10, 2022 at 5:34 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I’d talk with the folk in the supercharger thread. To make that kind of power you’ll need full intake, complete exhaust, supercharged with probably a 2.7” pulley or below if you are going the Magnuson route (assumed by the 6-7 psi in OP), a custom tune and possibly meth/water injection.
    Don’t forget about the trans that’ll grenade shortly after at that kind of power.
    A shift kit and a much larger trans cooler is what I’d go with.
    My truck is supercharged with 2.8” pulley, Volant intake, cat-back exhaust, & the -3° cam gears and it rips. Even on 35” tires and stock gearing.
    I’d guess about 300hp to the wheels if I were on stock tires.
  10. Nov 11, 2022 at 9:52 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  11. Nov 11, 2022 at 12:25 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    @Lucario Runner has claimed them. But he will have the supercharger ones for sale after I’m guessing.
    Torspd[QUOTED] likes this.
  12. Nov 12, 2022 at 7:45 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    :rofl::rofl: thats cute.
    Better off LS swapping.
    ZColorado likes this.
  13. Nov 13, 2022 at 7:32 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    nudavinci64 and Athlaos like this.
