cam shaft positions, possible shim replacements
Discussion in '1st Gen. Tacomas (1995-2004)' started by weebittysheamus, May 11, 2024.
  1. May 11, 2024 at 6:57 PM
    weebittysheamus
    weebittysheamus [OP] Member
    zach
    99 4x4 extracab 5 speed
    mostly stock, maintance as required. 3in lift
    got my head back on the rig today to hit a road block. my lobes on e3 and i3 are both touch my bucket shims after already findind tdc both on chain and the cam shaft gears them self.
    the engine seemed to be fairly out of alingment on dissassembly as the two mismatched colors on my chain were not on tdc. i hand cranked it to position, but am still dumb founded on what to do now.
    are the lobes pointed incorrectly? or are new shims in order (more than likely, as i cannot get any size feeler gauge underneath either e3 or i3). i am pretty stumpted. its been a long day dealing with it, but theres always tomorrow.
  2. May 13, 2024 at 4:43 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Oh man
    Need to get entire engine to TDC
    Bottom End and Top End
    Including the T chain, i think there are 6 separate T marks that must all be aligned
  3. May 13, 2024 at 4:49 PM
    ControlCar
    Steven
    Sugar Land TX
    As I found out……both top/bottom ends marks must line up
    at least your not wrenching on a Subaru 25EJ……there’s 12 freaking T marks that all must be pointed to correctly to be at TDC
  4. May 13, 2024 at 4:58 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Motor looks awfully dry to me,, i'd put some oil on that valve train to roll it over and get it set up.
  5. May 13, 2024 at 5:14 PM
    Taco y mas
    Taco y mas Well-Known Member
    SoCal
    Tacoma TRD Sport
    None
    I have not read the book on this engine. Does it say that TDC is mandatory for measuring some of the valve clearances? I have always pointed the lobes straight up and then measured the clearance.
  6. May 13, 2024 at 5:46 PM
    ControlCar
    Steven
    Sugar Land TX
    OP replaced head^^^^
  7. May 13, 2024 at 6:21 PM
    weebittysheamus
    zach
    ye got head machined. brand new head gasket and all the fun things.
    alright so the timing was fucked. so im in the process of taking the timing cover off, bought brand new chain set and tensioner because the old tensioner was maxed out so the chain had to have caused most of this problem in the first place.
    initially when i started tear down for the head gasket itself when i found tdc on cam shafts the bottom notch mark on the harmonic balancer was nearly an inch and a half off of the 0 mark indicated. it wasnt until i got my cam shafts installed and went to put my zip tied timing chain on that i kept running cirlces in my head about timing.
    anyways. im stuck at the moment trying to pop the crank shaft bolt to pull everything off. brand new gaskets seals and front seal are on their way from LCE.
  8. May 13, 2024 at 6:58 PM
    ControlCar
    Steven
    Sugar Land TX
    Sucks
    Good that you didn’t crank and noticed the problem!!!
    GL
