Cam Sleeve, Nut, and LCA Bolt OEM part numbers?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BenevolentMachination, Aug 4, 2019.
  1. Aug 4, 2019 at 3:41 AM
    BenevolentMachination [OP] Well-Known Member
    Ground Zero
    2000 Tacoma 3RZ 4WD Xtra
    As the title suggests, I am on the search for these OEM part numbers.
    ToyotaPartsDeal doesn't have a good description on their parts and the search function is caput.
    2000 Tacoma 4WD
    Any information on OEM:
    • Camber sleeve
    • Camber nut
    • Camber/LCA bolt
    and I'd thank you.
  2. Aug 4, 2019 at 6:58 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    90080-10066
    Part number for the bolts that hold the lower ball joint.
    I'd give you the remaining numbers but I used;
    Sankei 555 LBJs from low range
    Stock LCA/CAM bolt and sleeves etc since mine were in good shape
    I've got a set of SPC cam bolts and sleeves new in box since I didn't use mine.
  3. Aug 4, 2019 at 7:01 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    I have some used ones from a rust free truck im parting out i could sell
  4. Aug 4, 2019 at 7:24 AM
    mjhenks
    mjhenks Well-Known Member
    So.Cal
    04 Jade Green TRD V6 DC
  5. Aug 4, 2019 at 7:40 AM
    Ground Zero
    Sweet!
    Thank you all.
    I am going to buy new OEM parts.
  6. Aug 4, 2019 at 8:27 AM
    mjhenks
    So.Cal
  7. Aug 4, 2019 at 8:53 AM
    Ground Zero
