Cam sleeves seized but I can get the bolts out
Discussion in '1st Gen. Tacomas (1995-2004)' started by nat5nat11, Dec 8, 2019.
  1. Dec 8, 2019 at 3:52 PM
    nat5nat11
    nat5nat11 [OP] Well-Known Member
    Colorado
    2004 Tacoma Xtracab
    Hey guys. I was trying to take my LCAs off to do some frame painting. I was able to get the cam bolts and nuts off, and the cams can move, but the sleeve is seized in the LCA bushing. If I just leave it like this, can I still get an alignment or does that sleeve need to be able to move inside the bushing?
  2. Dec 8, 2019 at 3:54 PM
    eimkeith
    eimkeith Well-Known Member
    J Keith
    '96 4Runner, '03 Taco
    you can't align it like that. you'll need to cut them off and replace them (sawzall)
    Timmah! likes this.
  3. Dec 8, 2019 at 3:55 PM
    doorsidedown
    doorsidedown Well-Known Member
    anti-seize the new ones.
    eimkeith likes this.
  4. Dec 8, 2019 at 3:56 PM
    nat5nat11
    Colorado
    2004 Tacoma Xtracab
    That's what I wanted to avoid... Oh well =(
    GQ7227 likes this.
  5. Dec 8, 2019 at 3:56 PM
    eimkeith
    J Keith
    ^ absolutely, yes. (slather the shit out of them with anti-seize)
  6. Dec 8, 2019 at 3:58 PM
    doorsidedown
    I hear you, but the bright side is you don’t have to do all this work just because they seized... they’re already off - now it’s just fun.
  7. Dec 8, 2019 at 5:40 PM
    nat5nat11
    Colorado
    2004 Tacoma Xtracab
    What do you mean? I still have to cut them off and buy new parts. Doesn't sound like much fun to me.
  8. Dec 8, 2019 at 5:45 PM
    eimkeith
    J Keith
    it's not fun.
  9. Dec 8, 2019 at 5:55 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    but being able to paint the frame, hopefully with a better top-quality product, is the fun part!
  10. Dec 8, 2019 at 6:19 PM
    doorsidedown
    Sorry man, sarcasm doesn’t come thru much on a keyboard. Sorry you have to do it - I know it’s a pain in the ass.
  11. Dec 8, 2019 at 9:43 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    The sleeve in the bushing doesn't turn. The bolt turns inside the bushing sleeve. You stated that you removed the nuts and bolts.
    Sounds normal to me.
    Speedytech7 likes this.
  12. Dec 9, 2019 at 7:01 PM
    nat5nat11
    Colorado
    2004 Tacoma Xtracab
    True. It's going to look a lot better with fresh paint.
  13. Dec 9, 2019 at 7:01 PM
    nat5nat11
    Colorado
    2004 Tacoma Xtracab
    No worries dude. Sarcasm and computers is hard...
  14. Dec 9, 2019 at 7:04 PM
    nat5nat11
    Colorado
    2004 Tacoma Xtracab
    One side of the cam adjuster is a giant sleeve that the bolt goes through. That is stuck in the LCA bushing sleeve so I can't pull the cam adjuster out. I already took apart the other side just fine. This side doesn't come out of the LCA bushing. That's not normal.
    mechanicjon[QUOTED] likes this.
  15. Dec 10, 2019 at 3:26 PM
    eimkeith
    J Keith
    yeah, go ahead and cut it - you'll end up there anyway. (btdt)
  16. Dec 10, 2019 at 3:28 PM
    eon_blue
    Azusa, CA
    Same here, I was under the impression the bushings aren't supposed to move and are supposed to be pressed out? Assuming we're talking about normal OEM bushings and not the poly ones.
  17. Dec 10, 2019 at 4:44 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    mechanicjon and eimkeith like this.
  18. Dec 10, 2019 at 4:54 PM
    Timmah!
    TIM
    Hey Jon, I think you misinterpreted what he's saying. You are correct that the sleeve of the OEM bushing doesn't turn because it's incapsulated in the rubber. I think what he's saying is the cam adjuster sleeve isn't turning inside the bushing sleeve. The bolt actually turns inside the cam adjuster sleeve and doesn't turn inside the bushing sleeve.
    In order for an adjustment to made to the camber, the cam sleeve needs to be able to turn inside the sleeve of the bushing. If they get locked up due to corrosion, the only way to deal with it is to cut out the cam adjuster sleeve, press out the old bushings, press in new ones and install a new cam adjuster ideally coated with some anti-seize so you don't have to deal with this issue again. I slathered my cam adjuster sleeves with copious amounts of anti-seize because cutting out the adjusters sucks juevos.
  19. Dec 10, 2019 at 4:57 PM
    eimkeith
    J Keith
    Thanks Tim! (better said that I could have)
    Timmah! likes this.
  20. Dec 11, 2019 at 9:10 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Where are you guys ordering replacement Cam's?
