Cam Tabs Seized?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gunshot-6A, Aug 13, 2018.
  1. Aug 13, 2018 at 10:27 AM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Took my truck in for an alignment, and it appears the cam tabs are on their way to being seized. Can still move, but very combative. Hit it with "a shitload of PB blaster" per the tech, and it moves, but not as much as they'd like. Got it "good enough" and told me to come bring it back in a few days when the penetrating oil has soaked in.
    Realistically, what are my options for the future? Bolt/tab replacement, new LCAs, something else?
  2. Aug 13, 2018 at 10:35 AM
    Johnders
    Johnders Spacer Lift Survivor
    2010 Black Access Cab Tacoma Base
    2" Lift , 265/75R16 tires, K& N filter, MBRP Exhaust
    You can buy the cam bolts online most places for about 40 bucks, or spend a little extra and get greaseable ones for about double that.. I cant imagine you would need anything else beyond that..
  3. Aug 13, 2018 at 10:44 AM
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    This is not uncommon on our trucks. I bought my truck knowing they were seized and would have to be cut off. If I were you, I would purchase some OEM replacements (suggest staying away from Moog) and have them on hand for the next time you get the alignment done...I wouldn't replace them just yet since you paid to have your alignment done. Maybe hit them with some more PB blaster in the interim so they don't get too much worse. Hopefully, you can get those bad boys out before they seize up in the bushing, if they haven't already. Otherwise they might have to cut them out and either have new bushing pressed in or replace the LCA which is just more unnecessary expenditure. My 2 cents.
    slomoe and DrFunker like this.
  4. Aug 13, 2018 at 10:49 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    My alignment guy recommends pulling the bolts and slathering them with antiseize. I haven't done that yet but regular shots of PB Blaster, Sea Foam Deep Creep etc have become a regular item whenever I'm under the truck.
    DrFunker likes this.
  5. Aug 13, 2018 at 10:51 AM
    Pigpen
    Dan
    Northwest Montana
    Unchained 5150 likes this.
  6. Aug 13, 2018 at 10:54 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Since they apparently still move pull them, clean them, light sand to knock of rust, and grease/antiseize them.. Then look into replacing them if they are too badly rusted.
  7. Aug 13, 2018 at 10:54 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    I'd recommend pulling the cams since they're not seized yet. Most likely covered in surface rust. Depending on how bad they are, you can choose to replace with new or wire wheel them and give them a good coating of grease and reinstall (then get an alignment). Also wire wheel and grease the inner sleeve of your LCA bushing. I did that with mine and they turn with very little effort and are protected from seizing in the future. Regreasing gets added on to my major milestone maintenance list along with flushing coolant and trans.
  8. Aug 13, 2018 at 10:55 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Replace em, lube em up with anti seize or Lucas red-n-tacky grease, slap em back in, get it aligned and dont worry about them
    DrFunker and MattCowsmasher like this.
  9. Aug 13, 2018 at 10:59 AM
    Gunshot-6A
    Conner
    Everett, WA
    I got the Big O alignment deal where you can get re-aligned like 4 or 5 times in a year. I was gonna have to take it in again in the next few weeks after I installed a bumper and tweak the coils anyway, so I may just order the SPC replacement kit.
    Had I not just put in Kings (hence the alignment) I would go for the TC stock lower kit, but another 1700 + labor isn't super appealing right now.
  10. Aug 13, 2018 at 11:00 AM
    Gunshot-6A
    Conner
    Everett, WA
    As my luck would have it, our machine shop guys came into my office this morning and was like "your truck is bad ass; you'll probably want this since we were gonna toss it"; And then handed me a mayonnaise sized jar of anti-seize.
  11. Aug 13, 2018 at 11:01 AM
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    If you got that deal, then the cost of the alignment isn't really a factor, and I agree with what most have said, sooner rather than later.
  12. Aug 13, 2018 at 12:23 PM
    Gunshot-6A
    Conner
    Everett, WA
    Good news is the tech that worked on my truck is the resident Tacoma/FJ expert as well as fellow enthusiast. Sounds like we are gonna get this figured out one way or another.
  13. Aug 13, 2018 at 12:35 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Which location did you go to?
  14. Aug 13, 2018 at 12:36 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I purchased the cam tab bolt replacement kit from Wheeler's when I got my cam tab gussets.
    I figured while I'm in there I'll remove the old bolts, lather them in anti seize and throw them in. Should be good.
  15. Aug 13, 2018 at 12:39 PM
    Gunshot-6A
    Conner
    Everett, WA
    Big O in Sandy Just of 9000 South. I live 100 yards from it, and now I know the tech(s) there know their stuff. Had a few people point me there in the toyota community.
  16. Aug 13, 2018 at 12:41 PM
    Gunshot-6A
    Conner
    Everett, WA
    The SPC kit with the poly sleeve? I was just looking at it on Wheeler's.
    geekhouse23[QUOTED] likes this.
  17. Aug 13, 2018 at 12:45 PM
    geekhouse23
    These guys:
  18. Aug 13, 2018 at 12:46 PM
    Gunshot-6A
    Conner
    Everett, WA
    Yup, those are the ones. Any complaints about them?
  19. Aug 13, 2018 at 12:50 PM
    GHOST SHIP
    GHOST
    FYI, if you manage to get grease on the threads of the cam bolts, it changes the torque spec. You might get a clunk if you torque to factory specs. If so, just give it another ugga-dugga or two and you should be good. Always remember to double check suspension torque after a few days.
    DrFunker and geekhouse23 like this.
  20. Aug 13, 2018 at 12:52 PM
    98tacoma27
    Ben
    Not Beech Creek
