Camber and Caster Adjustments for lifted 2021 TRD Off Road
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Billo47, Dec 8, 2021.
  1. Dec 8, 2021 at 2:02 PM
    Billo47
    Billo47 [OP] New Member
    Bill
    2021 Grey Tacoma TRD Off-Road
    4" Lift, 1.5" spacers on all 4 wheels
    I have a '21 TRD Off Road 4x4 that I just had a 4" lift installed. I am getting new tires (285 70/R17) and wheels installed next week. The mechanic at Firestone asked me what I wanted the casters and camber set at. As a newbie to this world, I had no idea (I figured that would be something they would know). Does anyone have any recommendations on these settings? Thanks in advance!
  2. Dec 8, 2021 at 2:12 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    0 camber 3 - 4 caster 0 toe
    Billo47[OP] and rlx02 like this.
  3. Dec 13, 2021 at 7:27 PM
    Billo47
    Bill
    Thanks!
    71tattooguy[QUOTED] likes this.
  4. Dec 13, 2021 at 7:32 PM
    Bishop84
    Bishop84 Well-Known Member
    You need arms for 3-4 caster and 0 camber. They are ideal numbers though.
    You want highest caster, and lowest camber. Typically you'll get 1.5-2 degrees caster and 0.5-1.0 degrees positive camber on a lifted truck without aftermarket arms.
    Tacoma is 0.16 total toe or 0.8 toe each. Not Zero.
  5. Dec 13, 2021 at 9:47 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    It depends on a lot of things.
    On a stock truck, caster is +2, camber is +0.5 and toe is +0.05. Caster varies +/- 0.2 across the different models, but camber and toe are pretty much the same. There are legit reasons for said measurements; stability, wheel returnability, wheel maneuverability, dynamic accountability, etc.
    Most people don't realize, an alignment is a static measurement. Things change when dynamic forces are introduced under acceleration, cruise and braking. When you change the SAI and scrub radius with lift, taller tires and offset wheels, you significantly change the dynamic forces and their interaction with the steering. Not to mention, the changes in steering geometry associated with lifting...
    Most often, people will recommend higher caster for no other reasons than stability, wheel returnability and most notably, tire clearance. The latter, I do not consider a legit reason on it's own; not to say there aren't legit reasons for increasing caster. For example, a lifted truck will lose SAI. SAI is +12 on a stock truck. SAI is a stability angle, as much if not more so, than caster. It is the reason you can get by with relatively low caster(+2) on a stock truck. By increasing caster, you are basically you're trying to regain mechanical advantage and stability over the tire by increasing leading trail. But, there are 'costs'...
    In general, the more you change things, the more compromises you will need to make.
    What is the intended use? Daily driver? Dedicated offroader? Is tire wear critical? Do you want it to favor straight line, higher speed turning, low speed maneuverability, etc.? How much did SAI and scrub change?
    So yeah...what do want?
    Frankly, I'm surprised a Firestone tech gave you the choice. But, toe should also have been an option.
    What kind of lift? At 4", I suspect you have a drop bracket lift? Those usually claim to retain factory geometry; not that I've ever heard anyone verifying it.
    What are the specs on your new wheels?
