camber question...new UCA recommendations?
Discussion in '1st Gen. Tacomas (1995-2004)' started by amp3d, May 15, 2017.
  1. May 15, 2017 at 6:45 AM
    amp3d
    amp3d [OP] Well-Known Member
    Mark
    Toronto
    2002 Double Cab TRD Offroad, 2012 Access Cab
    Hey Guys,
    Toyota recently replaced my frame, and at the same time they installed some 5100s up in the front, set to 2.5" based on recommendations here. Love them! Man it rides so much better now than the 16 year old shocks that were there :D
    Anyways, when doing the alignment they said they could not get the camber in spec and that I would need some upper control arms. I was originally under the impression that with the 2.5 I would have been ok with the stock OCA, but apparently I was wrong?
    Just seeing what you guys would recommend.
    Any ideas?
    ChadsPride likes this.
  2. May 15, 2017 at 4:17 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    boostedka likes this.
  3. May 15, 2017 at 4:18 PM
    amp3d
    Mark
    Toronto
  4. May 15, 2017 at 5:12 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    Use the stock arms and install energy suspension control arm bushings. I just did energy suspension for he upper/lower control arms and the steering rack. I have been very happy with them. And the bushings cost like 37$ for top and bottom.
    I also installed bilstein 5100's on the highest setting and my alignment was perfect. Could be bad bushings
    amp3d[OP] likes this.
  5. May 15, 2017 at 5:28 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    Sorry, I fixed it. Some times my phone doesn't copy the URL and it pastes the last thing I copied.
  6. May 15, 2017 at 5:43 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    should be able to get camber pretty good. its castor that goes out of spec
  7. May 16, 2017 at 5:27 AM
    amp3d
    Mark
    Toronto
    That's so weird. My truck definitely has visible positive camber on the wheels :/ I'm really shocked as I thought they'd be able to get it in spec, at least not far enough out that it's noticeable. My friend noticed it just walking up the driveway the other day :/
  8. May 16, 2017 at 5:46 AM
    amp3d
    Mark
    Toronto
    This looks like a great option. I dont know though, the camber issue is visibly noticeable, I can't imagine bushing bringing them back in to spec that much? But, maybe. I wish that Toyota gave me more info on it when they did the frame replacement.
    I think I'll go with your options first. Were your old bushings hard to remove?
  9. May 16, 2017 at 5:58 AM
    01GreenTacoma
    I used an oxy/acetylene torch and pushed them out by hand. Took about a minute with the torch to heat the mm enough to push it out.
  10. May 16, 2017 at 6:08 AM
    amp3d
    Mark
    Toronto
    Thanks, Im going to give this a go I think as it's the most cost efficient way first. If it doesn't help, I'll have to look into getting some different control arms. It seems anytime I touch my truck I run into some issues that others didn't, lol.
    I can't for the life of my figure out why the camber is out so much. :D
  11. May 16, 2017 at 8:29 AM
    01GreenTacoma
    The worst part was just getting the dang control arms off. You have to remove a few things in the engine bay in order to get the bolts out.
    Do you have any pictures of your alignment/UCA's?
