camburg 4'' spindles
Discussion in 'Long Travel Suspension' started by bluetaco80, Sep 1, 2010.
  1. Sep 18, 2010 at 11:10 AM
    #41
    milo39
    milo39 Well-Known Member
    myles
    downey,ca
    07 doublecab prerunner trd off road
    i got a question!! im planning on getting my lift soon but now im all mixed up on what i should get.. im either planning on the icon stage 2 or the camburg spindles.. wish i could afford both but its one or the other for rightnow :) id like to see what you guys would suggest and maybe some pros and cons about both of them.. im looking for something thats reliable and wont f**k my $hit up.. thanks.. and if this is already a post somewhere else im sorry and can you telll me where i can find it.. thanks again..
  2. Sep 18, 2010 at 12:48 PM
    #42
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    spindles, it won't mess with your ride.
  3. Sep 18, 2010 at 1:17 PM
    #43
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Yeah the spindles are $25-$26k, and he'll throw in the truck for free!! That's one hell of a deal.:D
  4. Sep 18, 2010 at 1:40 PM
    #44
    bajamoon
    STEVE
    Whittier
    You got it. I will even toss in a pine tree sir freshiner lol
  5. Sep 18, 2010 at 4:21 PM
    #45
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Well for a guy who desert wheels, the spindles won't do much for you except lift the truck 4" higher. The icon stage two will considerably enhance your offroad capabilities at the expense of making your street ride suffer (result of cranking down the coils to achieve lift). Put the two together at no spring pre-load and you have an ubeatable combination other than going long travel.
  6. Sep 18, 2010 at 4:27 PM
    #46
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    If you don't want to push your truck hard than just get the spindles first. If you want to drive it like you stole it than get the icons first.
  7. Sep 19, 2010 at 12:49 PM
    #47
    milo39
    myles
    downey,ca
    thanks for your guys help.. guess ill be getting spindles!
  8. Oct 27, 2010 at 4:41 PM
    #48
    Blaise22
    Blaise22 Well-Known Member
    Blaise
    California
    09 prerunner trd offroad
    Camburg 4.0 race spindles, coilovers, 285/75/16 Yokohama Geolanders mounted on 16" KMC Hoss wheels, Aero Turbine 2525
    so I can use my none long travel camburg spindles with the camburg LT kit if I decide to buy it?
  9. Oct 27, 2010 at 5:43 PM
    #49
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    i dont think so...
    the camburg LT uses a lower uni ball, the stock susp uses a ball joint
    thats why camburg offers 2 diff spindles
  10. Oct 27, 2010 at 9:19 PM
    #50
    Blaise22
    Blaise
    California
    bummer I thought thats what the OP was asking
  11. Oct 27, 2010 at 9:24 PM
    #51
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    last time i emailed them about a month or so ago, they said my spindles would work :confused: then a couple years ago they said it wouldnt work :confused: but the last work was they work so ya lol
  12. Oct 27, 2010 at 9:26 PM
    #52
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    can you put lt spindles on stock truck? in cas you want to go with lt later?
  13. Oct 27, 2010 at 9:28 PM
    #53
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Why don't you guys just call Jerry at Camburg? lol The owner would be able to tell you yes or no.
    I thought the only difference between the two was the LT one doesn't have a sway-bar mount.
  14. Oct 27, 2010 at 9:33 PM
    #54
    08pretaco
    az
    you can order the sprindles with or without...i run without
  15. Oct 27, 2010 at 9:37 PM
    #55
    kinkrider101
    santa barbara
    wheels and tires
    well it would be a bummer to get spindles..then lt and not be able to use the spindles
  16. Oct 27, 2010 at 10:00 PM
    #56
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Camburg only has one type of spindle and you can use it on a stock truck or lt truck. It all bolts up the same
  17. Oct 27, 2010 at 10:05 PM
    #57
    kinkrider101
    santa barbara
    wheels and tires
    then why do they sell 2 different versions of the spindle?
  18. Oct 27, 2010 at 10:10 PM
    #58
    cummins6speed
    Its the same spindle, you can either get it with tabs for a swaybar or with out tabs for a swaybar
  19. Oct 27, 2010 at 10:11 PM
    #59
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    x2...
    they have two different part numbers... one for stock suspension and one for LT...
    if they are interchangeable, then it should be the same part number, right?
  20. Oct 27, 2010 at 10:12 PM
    #60
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    uhhhmmm! (clears throat!)
