Camburg alignment specs...
Discussion in 'Suspension' started by Tacomanator, Aug 21, 2010.
  1. Aug 21, 2010 at 2:58 PM
    Tacomanator
    Tacomanator [OP] Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    what numbers are you guys getting with Camburg "ball-joint" UCAs? did a search but only found numbers for TC uniballs.
  2. Aug 21, 2010 at 4:07 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    here are my numbers:
    what do you guys think? more caster? i have 885's with 5100's set at .85
  3. Aug 21, 2010 at 11:37 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    BUMP.... does anyone know if i can get more castor out of the camburg uca's??
  4. Aug 21, 2010 at 11:38 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    i got 0,0 and 2.4 on mine. i am guessing with the 885 and .85" your sitting at 3" with the coilovers. A lot of people get the best alignment results at 0,0 and 2.4 caster when the lift coilovers to 3"
  5. Aug 21, 2010 at 11:41 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    Thanks. ill call the shop that did my alignment and see if they can adjust it some more. hopefully they wont charge me another $70
  6. Aug 21, 2010 at 11:43 PM
    08pretaco
    Oliver
    az
    They shouldnt and if they do never go back. Most shops give you a 3 month 3k miles "warranty" I think. If the truck drives fine there really isnt any reason to adjust it. some people alter the caster to try to "allow" bigger tires with a less chance of rubbing on the cab mount because it pushed the wheel further forward. You can go back and ask them to change it but if it drives fine you should be alright
  7. Aug 21, 2010 at 11:50 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    it handles great just driving around town. ill see how it does on the freeway tomorrow. thanx for the input bro. rep commin your way ;)
  8. Aug 24, 2010 at 7:47 PM
    whitetacoma1
    whitetacoma1 White Tacoma 4X4
    Dan
    Alberta
    2009 and 1997 tacoma 4x4
    3" toytec Lift front OME 885s and AAL in the back
    2009 tacoma with toytec OME 3"lift 885 and aal in rear
  9. Aug 24, 2010 at 8:13 PM
    08pretaco
    Oliver
    az
    See thats where there is room for interpretation. For the trucks there really isnt a set ideal that works perfectly for every truck, there are only suggestions and thats where you start trying to dial in your truck and its characteristics.
  10. Aug 24, 2010 at 8:23 PM
    whitetacoma1
    Dan
    Alberta
    I thought this might help some one out. not too much info out there on the Alignment with a 3 inch lift!
  11. Aug 24, 2010 at 8:31 PM
    08pretaco
    Oliver
    az
    Oh it probably will help someone out. I always send out a PM to Chris most of the time when I have a question with alignment numbers and he always is great and helps me out!
