Camburg ball join uca questions
Discussion in 'Suspension' started by PupuleUlua, Aug 16, 2012.
  1. Aug 16, 2012 at 2:38 PM
    PupuleUlua
    PupuleUlua [OP] Well-Known Member
    Rod
    Honolulu
    2011 MGM TRD Sport DCSB 4x4
    Hi yall I got a few questions as to these camburg ball joint uca's? From what I understand benefits are low maintenance, quieter ride and best lower cost. Only thing against these is having to press oem ball joints in the assembly. I'm not a firm believer in reusing old parts and I believe oem ball joints only come as an assembly with the upper control arm at a hefty price. I heard some people have successfully installed moog ball joints while others had problems and camburg doesn't recommend them. Any one here has experience on these parts or knowledge on purchasing oem ball joints ala carte? I really like the looks of these compared to light racing uca's and main goal would be trying to get bolt on replacement saving time on install being this my only vehicle.
  2. Aug 16, 2012 at 3:22 PM
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
    I'm considering the 2 same UCA. Basicaly is LR UCA ball joint replacable. Does anybody have experience with the Camburg UCA with OEM or aftermarket upper ball joint?
  3. Aug 16, 2012 at 5:10 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Why don't you just go with the uniball instead of the bj style?
  4. Aug 16, 2012 at 5:18 PM
    YumaTRD
    YumaTRD 22R...Legends never die
    David
    El Cajon, CA hometown Yuma, AZ
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO's
    The Ball Joint UCA is low maintenance, quieter ride and $300 lower cost than the uniball
  5. Aug 16, 2012 at 5:22 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    this...^^^
    I have only had to replace my uni-balls once in 2 years and it's a breeze. Costs something like $80 for (2) 1" FK stainless uniballs now if you look hard.
    Here's a thread on it, but the pics are fubar. Sorry http://www.tacomaworld.com/forum/su...el-uni-ball-tc-uca-05-tacoma.html#post2804791
    and for people claiming low maintenance thats negligible. I had to replace my LCA BJ once just like my UCA uniballs so...........
  6. Aug 16, 2012 at 5:30 PM
    PupuleUlua
    Rod
    Honolulu
    Would be another option but trying to see if theres ppl out there with info on these. Only downside of uniballs is higher cost, possible noise and not sure which sets comes stainless steel being close to salt water for corrosion
  7. Aug 16, 2012 at 5:38 PM
    AcadianTaco
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    For me the problem with uniball is sea salt and road salt from November to April. Lots of salt, salt and more salt and than add more salt.
  8. Aug 16, 2012 at 5:40 PM
    XXXX
    sKiP
    05 Prius
    A higher price is what you get with a superior joint so no helping that one.
    They are only noisy if you do not maintain them by dripping some tri lube on them every month or so.
    I listed the brands I know have stainless in the link and before you buy just call and ask.
  9. Aug 16, 2012 at 5:43 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Uniball noise is not noticeable with the windows up. Leaf spring squeaking, on the other hand...
  10. Aug 16, 2012 at 5:50 PM
    bjasper
    bjasper Well-Known Member
    Brian
    Carmel, CA
    06 TRD PreRunner
    Dad's truck, minor mods.. Saving for my own :)
    This is a great thread, I was thinking about saving the money and buying the ball joint UCA, but I want Uni Balls. There are a couple on Wheelers, which would you recommend, FK's or Aurora's?
  11. Aug 16, 2012 at 6:00 PM
    XXXX
    sKiP
    05 Prius
    Aurora's = chrome (poop)
    http://aurora.thomasnet.com/item/ro...ib-16-3-2?&bc=100|1064|1066|1069|1076|3001300
    FK = Stainless (good)
    Chrome is harder so if your in a dry environment like the desert guys they are best. If your not in the desert I would assume the chrome is a major downfall for the rest of NA.
  12. Aug 16, 2012 at 6:00 PM
    YumaTRD
    David
    Solid Axle Yota
    I'm going with the balljoint UCA because I will only have an inch of preload on extended travel shocks. other than strength, i don't see why I should pay $300 more for a uniball setup.
  13. Aug 16, 2012 at 6:02 PM
    PupuleUlua
    Rod
    Honolulu
    Ty XXXX and others with there input.
    But still looking if there are info for oem ball joints ala carte and ppl that have these.
  14. Aug 16, 2012 at 6:10 PM
    XXXX
    sKiP
    05 Prius
    I have sen plenty of pics of carnage after a OE style BJ failed. Not good when your tire flops under the truck on the highway...not good at all.
    I have yet to see a uniball failure and they usually get beat harder then people with OE balljoints.
    NP. Wish I knew someone rocking them. Everyone I know that doesn't have a uniball has Light Racing.
  15. Aug 16, 2012 at 6:53 PM
    KenLyns
    Belly of the Beast
  16. Aug 16, 2012 at 7:17 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I like my burg bj's but they still squeak at times.....not sure if it's the ball joint or the bushing on the arms but I lube them when it happens. The design of having the cup open and acting as a bowl is a poor design IMO. If you can't fab a greasable dust cap (like mine), I'd either go with the LR or a uniball arm.
    PS - These have moog's in them.
  17. Aug 16, 2012 at 7:36 PM
    KenLyns
    Belly of the Beast
    All-Pro sells a dust cap for its 1.25" UCAs. Wonder if they'll work with the Camburgs?
  18. Aug 16, 2012 at 8:04 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    The cup is prob closer to a 1" or just smaller? AP's uca's look nice with that dust cap!
  19. Aug 16, 2012 at 9:54 PM
    KenLyns
    Belly of the Beast
    Camburg's uniball UCAs have 1.25" cups like All-Pro's. You think Camburg's balljoint UCAs have a smaller cup?
  20. Aug 16, 2012 at 10:05 PM
    bjasper
    Brian
    Carmel, CA
    06 TRD PreRunner
