Camburg BALL JOINT UCA
Discussion in 'Suspension' started by nvdeserted, Mar 28, 2010.
  1. Mar 28, 2010 at 11:53 PM
    nvdeserted
    nvdeserted [OP] Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Anyone have any experience with these? Was articulation noticably improved over stock? Any complaints?
    Has anyone seen the Camburg ball-joints vs Uni-ball on the trail? Is the Uni-ball considerably more impressive?
    Naysayers: I'm just doing research. I can swap the ball joint and install myself so I'd stand to save some $$$ if these are worth it.
    Thanks
  2. Mar 29, 2010 at 7:46 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    i dont know of anybody running them. your best bet is to prob call up camburg directly and ask them. camburg makes great products so i'm sure they are good but for $400 bucks and your arms still having ball joints, IDK
  3. Mar 29, 2010 at 1:45 PM
    nvdeserted
    Reno, NV
    This is exactly what I'm thinking. But as much as I love wheeling and definitely push the Taco I still put 90% of my miles on the highway; I don't know if I want to 'waste' a fine racing product (uniball) on highway miles = more replacement, maintenace, and squeek.
    I've done some more research on these and supposedly they allow for as much droop as the uniball but not as much tuck (haven't seen any numbers tho). They will correct caster on lifteds and generally look cooler than comprable LR's IMO. The MAIN difference is the strength of the joint, uniball is much stronger than any ball joint setup. Then again I don't jump.
    I've ordered the Ball-Joint one's from Wheelers today and plan on doing a full ramp test once I get them on, before after kind of thing. I'll post my results in a couple weeks.
    Ctupton likes this.
  4. Mar 29, 2010 at 3:34 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    cool, your right that they look way better than the LR UCA's. good luck :thumbsup:
  5. Mar 25, 2011 at 8:45 PM
    TmecTaco79
    TmecTaco79 Well-Known Member
    Adam
    Escondido,CA
    06 TRD PreRunner 4x2
    Bilstein 5100's, 33" BFG AT, Magnaflow
    I know this is an old thread but can you press the ball joint out and put a uni ball in these ball joint uca's?
  6. Mar 25, 2011 at 11:49 PM
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    I have them, no complaints. I don't do any high speed woops so this was my choice! I put new Moog ball joints as well.
    - Rich
  7. Mar 25, 2011 at 11:52 PM
    TmecTaco79
    Adam
    Escondido,CA
    Well that's good. They look good but I was just trying to be a cheap ass and see if I could buy these then press out the ball joint and then put in a uniball.
  8. Mar 25, 2011 at 11:54 PM
    eight3one_offroad
    Richard
    Haha. I probably would just buy the Uniballs rather then do redneck style!
  9. Mar 25, 2011 at 11:59 PM
    TmecTaco79
    Adam
    Escondido,CA
    Hahaha ya that's probably the best idea. Might have to place an order for some spindles while I'm at it haha
  10. Mar 26, 2011 at 12:52 AM
    eight3one_offroad
    Richard
    Damn son! That would be a sick setup. Set you're 5100s at .85 with spindles and new UCAs... Cali lean well if thats the look you are. after
  11. Mar 26, 2011 at 11:49 AM
    nvdeserted
    Reno, NV
    Negative. But, if you're handy at welding/fab you could easily just cut off the b/j cup and weld on a cup fit for u/b.
  12. Mar 27, 2011 at 12:42 PM
    TmecTaco79
    Adam
    Escondido,CA
    Na I'll probably get a 3inch leaf pack in the rear with some nicer shocks so it'll all look right.
    Hmmm... I wonder if it it would be cost efficient.
  13. Mar 5, 2014 at 10:29 PM
    SpeedwayBlueAlex
    SpeedwayBlueAlex Well-Known Member
    Alex
    Modesto
    SWB 4x4 TRD OFF-ROAD 6-SPEED
    Hey guys I jist purchased these from sunny out of DownSouthMotorsports! Im currently running billy 51s @1.75 w/eibach 1.6 springs along with mactrac 4 inch spindles. So really looking foward to getting mine installed! Also my offset on my rims are 4.25 and im on 285/75/16s so that being said do you guys now if my offset will affect my ucas fitting especially since im on a spindle lift ????? Any help would be greatly appreciated:)
  14. Mar 6, 2014 at 10:11 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Firebird likes this.
  15. Mar 6, 2014 at 12:55 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    ... this thread resurrection was brought to you by yotas4life.
    they'll clear the UCA with that BS
  16. Mar 6, 2014 at 6:19 PM
    SpeedwayBlueAlex
    Alex
    Modesto
    Hahahaha
  17. Mar 6, 2014 at 10:40 PM
    SpeedwayBlueAlex
    Alex
    Modesto
    What ball joints would u guys recommend to run with the ball joint uca for camburg ?? Cant run moog apparently and my ball joints are prettt damaged its time for new ones
  18. Mar 6, 2014 at 11:08 PM
    BudMan
    BudMan knee scooters R us
    Bret
    Alameda, CA, (Bay Area)
    06 TRD Sport DC 4x4
    stuff
    I have Camburg BJ UCA with stock bj's, they were fine to re-use. I would have gone Moog if stock had toomuch play to re-use. Apparently, the problem is the tolerance on the Moog dimensions. I have heard about 5/10 work fine, 5/10 bj's are too big. Freezing the bj and heating the UCA are probably your best bet for Moogs. If it seems like more force than necessary is required (ie 10 ton press) STOP. That is when the damage will occur.
    As far as other bj's, IDK :notsure:
    I don't know why Toyota considers the 2nd gen BJ a non-serviceable part. You have to buy the whole UCA to replace the stock bj. Mine pressed out/in no prob.
  19. Mar 6, 2014 at 11:20 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    as Wheelers suggested,go with the pre-installed option. No risk to you as the customer.
    After making some measurements, the Moog parts and the Camburg UCA do meet the minimum spec to install. Freezing the BJ, and heating the UCA in the oven worked for me, along with a vise and the BJ C clamp. A press would have been better. Make sure the BJ starts straight as that is key.
    I chose BJ style over uniball, as the environment here for a DD involves mud, salt, winter snow, ice, etc. I felt a uniball would require constant maintenance, and not survive in the dirty environment.
  20. Mar 6, 2014 at 11:33 PM
    SpeedwayBlueAlex
    Alex
    Modesto
    Thanks guys. I guess ill just reuse my oem ball joints even though they need to be replaced:rolleyes: im assuming its to very common for ball joints to dsmage on tacos maybe thats why they dont sell them separately ??
