Camburg Ball joints Alingment
Discussion in 'Suspension' started by meafordmike, Apr 19, 2010.
  1. Apr 19, 2010 at 8:32 AM
    meafordmike
    meafordmike [OP] Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    I just ordered a new 3 inch lift. Radflo coil-over’s and with OME Dakar’s rear leaf pack. I plan on setting the coil-over’s to about 2inch over stock and removing the 3rd leaf down from top on the Dakar’s.
    I am getting the new Camburg Ball joints UCA and was wondering if the Alignment will be an issue. I am told the UCA does not have adjustment like the LR UCA. If the caster is built into the UCA what should my #s be at the end?
    Toe=0
    Camber=0
    Caster=2.5
    I am running BFG All terrain TA/ko 265/75 16 on FJ cruiser Rims
    Please take it easy on me, as I am new to lifting. (I have used the search)
  2. Apr 19, 2010 at 8:47 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    I believe the caster is built in to those uca's. No adjustment needed. I've heard 0-toe,0-camber, and 2.5-3.0 positive caster will be good.
  3. Apr 19, 2010 at 8:48 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    chris 4x4 alignment specs for a 3" lift: 0, 0 and 2.7 :)
    thats whats worked best for him
  4. Apr 19, 2010 at 6:02 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Correct. The CMBG b/j uca add 2* of caster.
  5. Apr 20, 2010 at 5:26 AM
    meafordmike
    Thanks for the reassurances, I was thinking I could switch back to LR if needed but the camburg’s seem better.
