camburg lift spindles with tc lt kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skinzusmc, Apr 29, 2012.
  1. Apr 29, 2012 at 10:50 AM
    skinzusmc
    skinzusmc [OP] Member
    lucan
    norco
    2011 tacoma prerunner
    k&n cold air, spin tech muffler, total chaos 3.5" lt kit, fox coil overs, kmc wheels, nitto 285/85/18 tires, fiberwerx front fenders.
    i recently purchased total chaos' lt kit for my 2011 taco and i have no preload on the springs but it droops in the front a little more than i want it to. i was told to tighten up the springs but ill lose that nice feel. i dont want to do that so my next solution was lift spindles. but i hear stories of needing to change out the upper control arms to hiemed which are over 600 bucks more. do you think im able to run the lift spindles with my bushing a arms with no caster/camber issues?
  2. Apr 29, 2012 at 10:53 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    im running the camburg spindles with camburg LT and no heimed uppers...dont see why you would need to on the TC kit
  3. Apr 29, 2012 at 11:18 AM
    racer1x
    racer1x Well-Known Member
    campbell ca
    05 Taco
    Too many
    I have TC uca's and camburg spindles,there is no negative effects to using the combination. You will have high caster between 4-5 deg, but from what everyone has told me it is beneficial to having high caster.
  4. Apr 29, 2012 at 11:20 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    do it, the camburg spindle works, with the tc spindles you need all the other stuff
  5. Apr 29, 2012 at 8:30 PM
    skinzusmc
    lucan
    norco
    ok thanks for all the help appreciate the fast answers ha!
