CAMBURG LT!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by calixto25, Jul 24, 2013.
  1. Jul 24, 2013 at 4:03 PM
    calixto25
    calixto25 [OP] Well-Known Member
    Arizona
    TRD sport
    Hids, billet grille, headlights, fog lights, k&n intake, throttle body spacer, led taillights, led bulb conversion.
    I am interested in getting CAMBURG long travel for my truck. I have CAMBURG spindles on it now. I'm a broke ass college student so I want to piece everything together. I was thinking about buying the CAMBURG 1in uniball upper control arms but I am not sure if they are the same ones that are sold with the LT kit. I don't want to spend twice as much money.
  2. Jul 24, 2013 at 4:04 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    No they are not the same, save your money and do it once and do it right
  3. Jul 24, 2013 at 4:10 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    says the guy who has had two different lifts, multiple headlights, and is constantly confused on the direction he wants to take his truck..
    :p
    but.. he's right.. save up. :thumbsup:
  4. Jul 24, 2013 at 10:22 PM
    PLC721
    Patrick
    Chandler, Az
  5. Jul 24, 2013 at 10:30 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    I think thats happened to every guy whos gone LT. Learn from us dont waste your money!
  6. Jul 25, 2013 at 10:07 AM
    calixto25
    Arizona
    TRD sport
    Ok thanks for the info guys. Now I have to start saving my pennies.
  7. Jul 25, 2013 at 10:20 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Save save save
  8. Jul 25, 2013 at 10:25 AM
    KayStrait
    KayStrait Camburg Girl
    Kayla
    Huntington Beach
    '98 Desert Dune SR5 4Runner
    As said earlier... unfortunately, the Camburg uniball UCAs are a couple inches shorter than the L/T UCAs. I get this question a lot, because I know everyone is on a budget and try to piece kits together. Usually I would recommend to either wait until you can purchase the L/T kit, or go for a "mid-travel" kit and then when the time comes, sell it and go for the L/T.
    If you have the 4" lift spindle now, and you are still running the stock UCAs, you could run into some problems down the road. Anytime you lift a truck, the stock arms end up becoming a limiting factor with your suspension. With our uniball UCA you are not only replacing the weak factory b/j with a bigger 1.25" uniball but you will also gain more wheel travel. Like anything, modifications and upgrades all depend on how you are using your truck and how much you are wanting to spend.
    If money is an issue, you can always go for the ball joint UCAs, they are half the price and will correct the geometry of the arm but utilize your stock ball joint. This is an option if your ball joints are still in good condition. If not, it will be a pain to try and find replacement ball joints that are consistently made.
    Lemme know if you have any other questions about our products and I will surely help ya out :)
  9. Jul 25, 2013 at 10:27 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
  10. Jul 25, 2013 at 1:03 PM
    anthony250f
    Anthony
    San Diego, CA
    i doubt his uca's are a limiting factor...unless hes running ext travel shocks.
