Camburg spindle Backspacing issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DreDog, Oct 5, 2011.
  1. Oct 5, 2011 at 10:26 PM
    DreDog
    DreDog [OP] Well-Known Member
    Andrew
    If I have a wheel with a 5.5 backspace, people say that. 1.25 inch wheel spacer will make my wheels/tires fit.
    Ok now..
    If I have a wheel with. 5.0 backspace, could I run a .75 inch spacer?
    ..like does cutting 0.5 in off the wheel mean I could cut 0.5 off the spacer?
    Or does it not work like that?
  2. Oct 6, 2011 at 10:46 AM
    DreDog
    Andrew
    If I need a 1.25 spacer with 5.5 bs wheels to clear my spindles
    Could u use a 0.75 spacer with a 5.0 bs?
  3. Oct 7, 2011 at 12:34 PM
    TacomaChris
    TacomaChris Well-Known Member
    I think so - 4.5 is what's required at the most. So if you're running 5 bs and get a .75 spacer it puts you at 4.25 bs from what I understand so that should work fine.
