Camburg Spindle Install HELP
Discussion in 'Suspension' started by dira1987, Apr 21, 2011.
  1. Apr 21, 2011 at 11:33 AM
    dira1987
    dira1987 [OP] Well-Known Member
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    Ok guys, so i finally got on the install with the camburg spindles. With the help of the threads and pictures on here i managed to get the old ones off just fine and put the new ones on. We adjusted the alignment the best we could to get it drivable to take it to get it aligned. When we were taking it around the block, the abs sensors went off and now we cant really drive it anywhere. I know its the abs lines, but what can i do to check them? Will damage be visible? Has anyone else had this problem? Im going to check it out again today when i get off of work (never do an install on a week day, i learned the hard way). THANKS!!!!!!!!!!!
  2. Apr 21, 2011 at 12:33 PM
    racer1x
    racer1x Well-Known Member
    campbell ca
    05 Taco
    Too many
    Did you put the sensors in before the hub, if so it may have gotten damaged.
  3. Apr 21, 2011 at 12:38 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    unscrew the sensor and look at it.
  4. Apr 21, 2011 at 12:43 PM
    08PRELB
    08PRELB Don't Tread On Me
    Adam
    805
    08 Prerunner LB
    Toy Tech Ultimate Lift kit,Buildt Right UCA's 285/70/17 BFG AT, Camburg Spindles, BHLM, K&N, Flow Master 50, Spider Trax, URD MAF CAL, Satoshi Grill, any time fog mod, 20% tint, Katzkins Leather Interior, FX-R Projector Retro
    I would disconnect the sensor and check for dirt or corrosion.
  5. Apr 21, 2011 at 1:25 PM
    dira1987
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    We put the sensors in after the hib, they were actually one of the last things we tied down. I will have to check them though to make sure they're not damaged or corroded i didn't think of that. Thanks for all the help guys!
  6. Apr 21, 2011 at 1:39 PM
    08pretaco
    Oliver
    az
    Did you make sure to tighten it down, I know that is was a bitch to get at and tighten and I just wanted to leave it alone lol
  7. Apr 21, 2011 at 1:41 PM
    dira1987
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    I bet we could have still tightened it down more thats for sure. We finished at 2 am so who knows exactly what we were thinking around then. If theyre not tightened in all the way will that cause the abs to freak out like that?
  8. Apr 21, 2011 at 1:46 PM
    08pretaco
    Oliver
    az
    IDK just trial and error. If it lose, tighten and see what happens.
  9. Apr 21, 2011 at 2:03 PM
    dira1987
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    Whats the worst that could be wrong? Are the repairs on those things crazy?
  10. Apr 22, 2011 at 1:44 PM
    dira1987
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    We got it figured out! The alignment was so off that it was causing the abs sensors to rattle when we drove. We reset the abs system and now its right as rain. It still drives really bad but itll have to do until i can get it aligned. Thanks for all the help!
