Camburg Spindle Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SilverTacoZack, Nov 2, 2010.
  1. Nov 2, 2010 at 4:55 AM
    SilverTacoZack
    SilverTacoZack [OP] Well-Known Member
    Zack
    Elgin, SC
    2011 FJ trail teams
    Hey guys after looking at all the lift options it seems for Prerunners, the Camburg lift spindles are totally worth it. However, I was trying to figure out, for one, if the Camburg spindles are VSC friendly, and what all else you would need to complete the kit. To get a level lift all around, so far i'm concluded you need the following:
    1. Camburg Spindles
    2. Longer brake lines
    3. New rear leaf packs (3 inch lift or so)
    Am I missing anything? Can all this be used with factory shocks/coils, or would new coilovers pretty much be a "must have" with this setup?
  2. Nov 2, 2010 at 7:29 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You'll need new rear shocks or shock extenders if you plan on lifting 3" in the back.
    You can use the stock shocks/coils up front if you like.
  3. Nov 2, 2010 at 7:32 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
  4. Nov 2, 2010 at 10:05 AM
    SilverTacoZack
    Zack
    Elgin, SC
    2011 FJ trail teams
    Hmm. Any advantages to the Camburg lift over just getting, say, Toytech coilvers in the front, besides the one inch extra lift? My purpose of lifting is mostly to fit bigger tires (at least 33 inchs)
  5. Nov 2, 2010 at 10:14 AM
    jodiddly33
    jodiddly33 Well-Known Member
    Jonah
    DFW
    2010 Golf TDI
    Advantages: keeps stock geometry (stock ride as well), won't wear out other parts like other lifts do
    disadvantages: expensive, only for prerunners
    once I have enough saved up, spindles and a leaf pack are on my list
  6. Nov 2, 2010 at 12:05 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    biggest advantage is that you will have stock geometry. w/ the toytec, you preload the springs and loose downtravel to the point where you almost dont have any. w/ the spindles, you get 4" lift and keep the OEM (~3") downtravel.
    i really wish i would have done it much sooner...
  7. Nov 2, 2010 at 6:52 PM
    SilverTacoZack
    Zack
    Elgin, SC
    2011 FJ trail teams
    Sweet, saving up for the spindles is the way to go. I'm kinda concerned about how to get a matched lift for the rear TSB springs though. I estimate I'd need about 2 inchs to match the 4 in the front from the spindles. Thats more than the AAL's will do I think.
  8. Nov 3, 2010 at 10:16 PM
    GTACO
    GTACO GTACO
    Gabriel
    Murrieta, CA
    07 PreRunner
    Camburg Spindles, Total Chaos UCAs & LCAs, Fox 2.5 c/o front, Fox 2.0 rear, All Pro 3" leafs, Dumped Borla muffler, AFE intake, DTF front bumper, Demello rear bumper.
    :popcorn:
    Thinking about doing this same set up.... What shocks would be needed for 3-4 lift in rear?
  9. Nov 3, 2010 at 10:27 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    i installed a set of OME springs/shocks and have DR coilovers cranked to about 1" and im sitting perfectly level, 25" from center of hub to bottom of fender, front and rear.
  10. Nov 4, 2010 at 5:03 AM
    SilverTacoZack
    Zack
    Elgin, SC
    2011 FJ trail teams
    Nice. All this is starting to sound pretty expensive to do the spindles though, plus i'm not sure i'd be confident doing the install myself which is gonna add more to the cost. Lol, think I might end up with just Billy 5100's in the front to level out my TSB lift, and 265's....
  11. Nov 4, 2010 at 5:07 AM
    sooner02r1
    sooner02r1 Well-Known Member
    You can fit 33" tires with no lift. All spring/shock lifts (or all good ones I should say) keep the stock suspension cycle, unless you get UCAs and extended travel coilovers, which give MORE uptravel, so lifting only changes tire clearance when the truck is sitting still. The second you stuff a tire up in the fender well, no more lift. So trimming in the fenders and chopping the body mounts are what will REALLY give you tire clearance.
    A spindle lift is the only way besides a drop bracket or long travel to really change the front end geometry. It moves your hub 4" lower on the LCA, and keeps stock geometry other than that, so it's basically a much better alternative to a drop bracket lift. The Camburg spindles also are .5" wider per side, which I'm a fan of. I would love to have some, just haven't ponied up the grand to do it.
    With that said, any lift combo will allow you to run the bigger tires, so you can research and determine what fits you best. Right now I'm running bilstein 5100s in front with 2.5" lift and TSB leaves in the rear. It's a cheap setup that works well for most stuff I do in my DD.
  12. Nov 4, 2010 at 6:09 AM
    SilverTacoZack
    Zack
    Elgin, SC
    2011 FJ trail teams
    How can you do 33 inch tires with no lift? I've been told 285/75/16's won't fit without mods.
  13. Nov 4, 2010 at 6:15 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    wtf are you talking about?! lots of bad info in this post.
  14. Nov 4, 2010 at 6:33 AM
    KPT
    09 Prerunner
  15. Nov 23, 2010 at 3:01 PM
    milo39
    milo39 Well-Known Member
    myles
    downey,ca
    07 doublecab prerunner trd off road
    all this is good info! from what i can kind of understand. lol.. ive asked this question before but im one that needs to know its going to work.. so i plan on doing the camburg spindles and the 1.5 all pro aal. from what i remember measuring that should leave my truck .5 higher in the front.. (which i like) i plan on trying to keep it stock as i can due to money but i want it to ride safe and not mess with anything so ill spend the money for that (pretty much id like it to last me awhile..i dont want to worry about something messin up.. since im not handy with the tools if you know what i mean.. ha..) sooo is that possible or do i need anything else? example..uca.. front/ rear shocks.. etc etc.. thanks for the help..
  16. Nov 23, 2010 at 3:17 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    That made me giggle, i didn't know that leaves were holding my suspension in the rear i thought it was leafs *sarcasm*. This is filled with useless info, don't listen to this crap, this is the equivalent to a ricer trying to give advice on engine mods but in suspension form.
