Camburg Spindles with 5100 set a "0" - help please.
Discussion in 'Suspension' started by tony92629, Nov 11, 2010.
  1. Nov 11, 2010 at 8:56 PM
    tony92629
    tony92629 [OP] Well-Known Member
    Tony
    Dana Point
    2010 White Tacoma Prerunner
    5100's all the way around. Front set at .85. Camburg Spindles. Camburg Uniball 1.25 UCA's. Total Chaos LCA skid plates. Custom Deaver 10 pack rear leaf spring. BFG AT KO's 285/70/17, Weathertech floor liners, Wet Okoles. Midland CB/PA, Firestick.
    I am upgrading my stock spindles and UCA to Camburg spindles with Camburg UCA Uniball set up - with the stainless steel extended break lines for a mid travel set up - light off road and fire roads. Plus I heard it will ride a lot smoother.
    I already have 5100's all the way around. I want to make sure my front end does not sit high with the spindle lift and I want to be as level as possible.
    I was planning to dropping my front 5100's from 2.5 to "0" after the spindle install. The rear is a TSB with a 1" block - for now.
    Will this set up be level or will I ride high in the front?
    Any suggestions or comments would be greatly appreciated.
  2. Nov 11, 2010 at 8:58 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    your still going to be high up front. try a toytec AAL along with the 1 inch block and you may be level.
  3. Apr 4, 2011 at 2:21 PM
    tony92629
    Tony
    Dana Point
    I figured it out.....
  4. Apr 4, 2011 at 2:27 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    What did u end up doing ????
  5. Apr 5, 2011 at 9:39 AM
    tony92629
    Tony
    Dana Point
    Went to Deaver and they made me a custom leaf spring pack. Sits perfectly level and rides better than stock.
  6. Apr 5, 2011 at 9:43 AM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
