Camburg Tacoma 05-16 Billet UCA's coming soon ...
Discussion in 'Camburg' started by motoxscott, Jun 3, 2016.
  1. Jun 3, 2016 at 3:17 PM
    motoxscott
    motoxscott [OP] Well-Known Member Vendor
    Scott
    Socal -> Hurricane, UT
    2017 Tundra - 2008 Tacoma
    Camburg, FOX, Method, General Tire, Deaver
    We're getting close to having our new series of billet upper arms ready to start shipping out for the 2005-2016 Tacoma's. More info to come but here are some quick points.
    • CNC machined from aircraft quality 6061 aluminum
    • Bolt-on uniball caps
    • FK 7/8" heim joints
    • FK 1.25" uniballs
    • Corrected caster for lifted trucks
    • Corrected camber for lifted trucks
    • Standard and high caster heim spacer settings (3-5.5 degrees positive caster)
    Here are a couple pics of them and one of our Tundra LT arms to show you the color they will be anodized.
    First sets will be available through SDHQ in Arizona.
    - Scott @ Camburg
  2. Jun 3, 2016 at 3:42 PM
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Reno NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    What would be the advantage over tubular?
  3. Jun 3, 2016 at 3:53 PM
    Mike330R
    Mike330R Well-Known Member
    Far West Phoenix
    '16 DC Offroad w/ stuff
    Very nice!
    Price point?
    Is the adjustable caster/camber really needed of Tacoma's?
  4. Jun 3, 2016 at 5:22 PM
    motoxscott
    Scott
    The benefits are in the details. With machining an arm you're able to bring features and designs that would be difficult or very costly to try and do with something tubular. Some aspects couldn't be done with a tubular arm. You have total control when CAD designing and machining a part with precision accuracy in every detail.
    They will retail for $1395/set. With the ability to adjust camber/caster it will allow the arms to work with more suspension kits out there with taller or lower ride heights. If someones frame is bent from an accident, you'd be able to compensate with the heim adjustment as well. It's not needed for everyone, but does give more tune-ability. Most wont adjust the heims, but we designed the arms and heim spacers to have a standard and high caster setting. The standard setting will give you 3-3.5 degrees of positive caster and the high setting will give you 5-5.5 degrees of positive caster, a 2 degree adjustment just by moving the heim spacers around without affecting your camber settings.
    When they get closer to being available we'll put up a lot more detailed info on our website.
    At the end of the day we wanted to design and build an arm at the highest level.
    - Scott @ Camburg
    Ihatetacomas likes this.
  5. Jun 4, 2016 at 10:35 AM
    Ihatetacomas
    Dylan
    Reno NV
    Ahh higher quality, I had to ask, you know how much crap people on TW talk about icon's billet arms so I had to check myself what the scoop was
  6. Aug 9, 2016 at 5:56 PM
    motoxscott
    Scott
    Here are some more pics ....
    camburg_taco1_web.jpg camburg_taco2_web.jpg camburg_taco3_web.jpg camburg_taco4_web.jpg camburg_taco5_web.jpg camburg_taco6_web.jpg camburg_taco7_web.jpg
  7. Aug 9, 2016 at 6:02 PM
    Ihatetacomas
    Dylan
    Reno NV
    Nice, heim joints?
  8. Aug 10, 2016 at 9:33 AM
    motoxscott
    Scott
    Yea we use FK 7/8" heims to allow for more adjustment if needed.
  9. Aug 10, 2016 at 11:10 AM
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks! Vendor
    SALES
    Gilbert AZ
  10. Aug 11, 2016 at 4:07 PM
    motoxscott
    Scott
    Few more pics now that we got the caps back from laser.
    Toynado likes this.
  11. Aug 15, 2016 at 1:08 PM
    motoxscott
    Scott
    Here's a diagram showing the different caster settings based on the heim spacer arrangement.
    Chris(NJ) and Toynado like this.
  12. Aug 26, 2016 at 5:48 PM
    motoxscott
    Scott
    Yes and No ... if you're referring to poly bushings at the frame squeaking than yes, since we use heim joints instead.
    If you mean from the uniball then YES because the cap helps keep dirt, grime, etc out of the joint and NO because at some point ALL uniballs regardless of brand can make some noise here and there. That's a whole other conversation, but most times uniballs squeak because they are dirty and just need to be cleaned.
    One aspect the machined arm does bring to the table is the fact that there is no welding to distort the cup the uniball presses into. That can help with squeaking and wear resistance.
    - Scott @ Camburg
    Toynado likes this.
  13. Aug 26, 2016 at 6:00 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2013 DCSB OR Spruce Mica
    Workin' on it....
    Subbed!
  14. Sep 9, 2016 at 3:58 PM
    motoxscott
    Scott
    Here's a set we put on a brand new 4-Runner with FOX DSC coilovers.
    Toynado and 808Statetolbz like this.
  15. Sep 9, 2016 at 4:22 PM
    Mike330R
    Far West Phoenix
    Gorgeous!
  16. Sep 20, 2016 at 12:45 PM
    motoxscott
    Scott
    another beauty shot lol
  17. Feb 1, 2019 at 4:45 PM
    AS73
    AS73 Active Member
    Tim
    Huntington Beach
    2012 Tacoma 4x4 TRD
    They look pretty Awesome with my Kings Also...
    Thanks Camberg
    808Statetolbz likes this.
  18. Feb 1, 2019 at 5:03 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Hawt!
  19. Mar 24, 2019 at 2:29 PM
    808Statetolbz
    808Statetolbz Active Member
    Oahu
    07 dcsb
    This will be my next upgrade soon but my question is, will this work with upper coil bucket tower gussets from total chaos?
  20. May 21, 2019 at 9:28 PM
    unk
    unk Well-Known Member
    San Jose
    2017 TRD OFFROAD
    FOX 2.5 Factory Coilovers w/resi DSC @fox ———————————————- Camburg Kinetik Series Upper Billet Control Arms @camburgracing ——————————————— FOX 2.5 Factory Shocks w/resi DSC @fox ——————————————— Icon Vehicle Dynamics AAL @ivdsuspension ——————————————— Baja Designs Squadron-R amber fog light kit @bajadesignsofficial ——————————————— RCI Bed Rack @rcioffroad ——————————————— Tepui KUKENAM 4 XL Ruggedized @tepui
    @motoxscott ever see this happen? Uniball hitting the UCA.
    CF77CED0-4DE9-4BBC-A89E-EB67FB6AD76E.jpg AD09A9EC-ADAA-453A-AAA3-C2C95E2FE8F0.jpg
