Camburg Trail Series +2 LT
Discussion in 'Long Travel Suspension' started by roguegs, Mar 2, 2022.
  1. Mar 2, 2022 at 8:46 PM
    roguegs
    roguegs [OP] Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
  2. Mar 26, 2022 at 12:39 PM
    ianjd10
    ianjd10 Well-Known Member
    Ian
    2019 TRD Offroad
    Bone stock
    The kit is pretty new. I am extremely interested in it so hopefully this thread turns into something
  3. Mar 26, 2022 at 12:43 PM
    Redfive11
    Redfive11 Well-Known Member
    La Mirada, CA
    2012 PreRunner
    FOX 2.5 EXTENDED TRAVEL w RESI /DSC CAMBURG UCA PELFREYBILT HYBRID FRONT BUMPER
    Yes. You can run your 2.5 fox or kings with this kit.
  4. Mar 26, 2022 at 1:04 PM
    roguegs
    Angelo
    V8 T4R
    I was able to get this kit at a discount…just wondering if I want to go this route or a with an actual LT kit with LT spec coilovers
    ianjd10 likes this.
  5. Mar 26, 2022 at 1:18 PM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Have you looking into the JD Fab +2.25” kit? I’ve been very happy with mine. You can use OEM spec coilovers with it, too. You’ll likely lose about an inch or so of travel by using them though with either kit. I’m running 8” coilovers and JD’s bombproof 934 CVs to get all the travel and strength I can out of it.
    I broke even selling my OEM spec Kings and getting 8” Fox, so that wasn’t really a selling point for me when choosing a kit, but I get it with shock lead times if you like shiny blue shocks.
    https://jdfabrication.com/collections/05-15-6-lug
  6. Mar 26, 2022 at 1:32 PM
    ianjd10
    Ian
    2019 TRD Offroad
    Bone stock
    I sent you a dm
  7. Mar 26, 2022 at 1:51 PM
    ianjd10
    Ian
    2019 TRD Offroad
    Bone stock
    Can you reference where you got the information that you can run oem spec coilovers with jd fabs kit? In their advertising they only state 8 inch universal coilover.
    roguegs[OP] likes this.
  8. Mar 26, 2022 at 2:00 PM
    roguegs
    Angelo
    V8 T4R
    I also am curious on this info. JD was my preferred way to go since they also move the wheel forward a bit. Main reason why they aren’t my top choice right now is strictly due to the lead times on King/Fox.
    I can get a TC +2 expedition kit with Radflo coilovers and triple bypass in 12 weeks
    Dayman Karate[QUOTED] likes this.
  9. Mar 26, 2022 at 5:00 PM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    @81Trekker can advise you best.
  10. Mar 26, 2022 at 5:02 PM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    I got 8” Fox coilovers from JD in about two weeks peak rona. Not sure about bypasses.
    JD is the absolute best to work with, too.
    roguegs[QUOTED][OP] likes this.
  11. Mar 26, 2022 at 5:30 PM
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Yes you can run OE kings, you will just loose about 3/4” of travel
  12. Mar 26, 2022 at 6:20 PM
    roguegs
    Angelo
    V8 T4R
    @thebaker @rob1208
  13. Mar 26, 2022 at 6:39 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    That's what you're told but lead times tend to be rough estimates right now. Best to find a vendor with product already on order or with stock if you're not willing to wait.
    It sounds like your desires are a bit scattered thought. Your asking about the Camburg kit due to the convenience/price, prefer the JD kit based of performance, yet are throwing in the TC kit with Radflos and bypass??? What are you trying to achieve in the long run and what is your priority?
  14. Mar 26, 2022 at 7:20 PM
    roguegs
    Angelo
    V8 T4R
    let’s just say if all 3 kits were right in front of me available off the shelf - JD Fab would be my choice. Main reason I’m attracted to it is the sealed uniballs and the movement of the wheel forward to help clear the cab. Camburg has claims it also does this but idk if spending the same coin on a pseudo-LT kit would be the best option
  15. Mar 26, 2022 at 7:33 PM
    81Trekker
    La Jolla SD
    JD kit is on the shelf :)
  16. Mar 26, 2022 at 7:40 PM
    roguegs
    Angelo
    V8 T4R
    I know! Now that it’s confirmed that it works with EXT Kings there might be a new order coming in lol
  17. Mar 26, 2022 at 8:03 PM
    ianjd10
    Ian
    2019 TRD Offroad
    Bone stock
    This would be cool especially because of the long lead time on coilovers right now. Didn’t set out looking for long travel but need new ucas after some hard wheeling told me spcs wouldn’t be the best choice for me, and what I want to do. And figure I might upgrade now instead of stock width replacements. Your kit and camburg are the only I am considering due to not using poly bushings in the lcas. So smart what you have done there instead!
  18. Apr 25, 2022 at 7:36 AM
    Kombi
    Kombi Well-Known Member
    Zack
    08 Tacoma 97 Fjz80 01 Tundra
    Camburg trail kit moves the wheel forward 1in, JD is 7/8s
  19. Apr 28, 2022 at 5:37 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I believe the Camburg kit does this with just moving the uniball forward and leaves the factory lower pivot mounts alone. The weakest part on the truck. This is where every body should start. Regardless of who's arms you use start with JD's LCA mounts. Then you might as well just do every thing else from JD.
  20. Apr 28, 2022 at 5:47 PM
    Kombi
    Zack
    Everyone does this on there LT including JD. JD however does offer the lower pivot upgrade separate of any LT
