Camburg Trail Series +2 LT
Discussion in 'Long Travel Suspension' started by roguegs, Mar 2, 2022.
  1. Mar 21, 2023 at 5:56 PM
    #61
    Strekcorp
    Strekcorp Member
    Texas
    2019 Voodoo TRD Pro
    Magnuson TVS 1900
    You are absolutely correct. It was a nightmare. Lesson learned I suppose. On the other hand I am learning a lot more about the truck faster than I thought I would. Camburg is closed and didnt get back to me about the shocks today so hopefully they will let me know tomorrow.
  2. Mar 22, 2023 at 12:45 PM
    #62
    vhinojosa4735
    vhinojosa4735 TXTaquito
    Vince
    Corpus Christi, TX
    2010 TRD OR Double Cab Taco 4x4
    2010 TRD Off-road Double Cab 4x4 McNeil Racing Fiberglass 3rd gen conversion all the way around. 4.56 nitro gears, Doug thorley long tubes, TRD exhaust, 37” Toyo M/T’s on 17x9 Method 312’s (5),Dirt King +3.5 Long Travel up front with 2.5 kings all the way around, durobumps up front, Alpharex headlights, Baja Design Fog lights, SR20” rigid bar, Demello Offroad Baja bumper, Dakar HD rear springs, prinsu rack, taco bed mat, AL off-road Trailgate,rci skid plate, full sound system, katzkin all leather seats, 10 pro comp rock lights, switch pro 8 switch setup, on board VIAIR compressor, smittybuilt 9k winch, total chaos cam tab gussets and spindle gussets.
    W
    where at in south Texas?
  3. Mar 22, 2023 at 2:16 PM
    #63
    Strekcorp
    Strekcorp Member
    Texas
    2019 Voodoo TRD Pro
    Magnuson TVS 1900
    @vhinojosa4735 McAllen. I have had trouble trying to take the truck anywhere. You in South Texas?
  4. Mar 22, 2023 at 2:24 PM
    #64
    Strekcorp
    Strekcorp Member
    Texas
    2019 Voodoo TRD Pro
    Magnuson TVS 1900
    Okay revision two to my math:
    For the FOX-880-06-418 extended travel (Camburgs exact recommended shocks for this kit)
    Total Shock Length 22.59 (Extended, Accutune says actually 22.48 on the product page) 17.55 (Collapsed)= Travel of 5.04 (Accutunes page says 4.89)
    I am seeing the shock fully extended with 26 inches from the same spot in the fender to the center of the hub.
    With the shock at 19 3/4 the slapper has engaged, technically this makes sense as there is 2 inches left on the slapper and just over 2 inches left on the shock.
    I put the wheel on and measured at extension and found that there is just at 10 and 1/4 or so inches from fender to wheel.
    As compressed as I can, I can get the wheel to 5 inches from the fender which puts the shock at 20 1/4 inches.
    So from these my math says half of my wheel is 15 and 3/8 inches as the wheel is 30.75 inches.
    26 subtract 15 3/8 gives me 10.625 inches from the fender at extension. The shock is 22.59 at this point we will say per the chart (longer version).
    With the shock at 20 1/4 inches (change of 2.34) the wheel has traveled 5 1/4 inches. (I am really seeing just over 10 but maybe thats user error)
    I am guessing this is a motion ratio of 2.24. so for every inch of the shock, the wheel moves 2.24 inches.
    With the shocks known distance of travel per factory 5.04 inches and the motion ratio of 2.24, I get 11.28 inches. which puts me about 1.8 inches short of the 13 inches stated by camburg when I called to clarify and what is up on the page now. (If I use acctunes other measurements I get 4.89 X 2.24 = 10.95) Which would be over 2 inches short.
    Waiting to hear back from Andrew at Camburg as I sent him a bunch of photos to see if there is something incorrect on the setup. Lord knows my math may be bad. Also I havent been able to find anything here on the site to really confirm or deny how I am measuring the aspect ratios for movement. Looking at the shocks angles and the angles that the wheel travels in the are not parallels so there may be a little bit of license that manufacturers take (or that I cannot account for) in measurements.
  5. Mar 22, 2023 at 8:53 PM
    #65
    vhinojosa4735
    Vince
    Corpus Christi, TX
    I grew up in La Feria, I live in corpus now. Did you take it to trucktoyz by chance? If you ever need help and don’t mind the drive I can get you figured out. I’ve installed plenty of different suspensions on a bunch of different yotas over here. My daily has a dirt king LT kit and I’m about to throw on a total chaos LT kit on my wife’s 4runner in the next couple weeks.
  6. Mar 22, 2023 at 9:09 PM
    #66
    erok81
    erok81 Well-Known Member
    Imposter
    Do you have the capability to pull the coilover, pull the coil, re-install the coil-less coilover, and properly cycle the suspension instead of these constantly revised measurements?
    TacoEspecial and desertjunkie760 like this.
  7. Mar 28, 2023 at 6:56 AM
    #67
    Strekcorp
    Strekcorp Member
    Texas
    2019 Voodoo TRD Pro
    Magnuson TVS 1900
    @erok81
    Yeah like I said, I should not rage post, but there is not a lot of information out there on this kit and I was desperate for input. The last measurements are pretty close to accurate after speaking with camburg. Apparently about an inch of travel is missing which makes sense as this was done with a tape measure and inclinometer on my phone not on cad, seems reasonable that a few missed decimals would add up to an inch, plus what they had accounted for through modifications to the hardware (They were able to get more travel out of their shock due to machining the internal spacers to get their numbers). Motion ratio was close to what they reported to me was established in their cad. I have to pull the coilovers this weekend so I will see what actual numbers I see and try and use some plumb bobs to account for arc as well as linear movement.
    Are you running this kit and seeing something different?
  8. Mar 28, 2023 at 6:57 AM
    #68
    Strekcorp
    Strekcorp Member
    Texas
    2019 Voodoo TRD Pro
    Magnuson TVS 1900
    @vhinojosa4735 I may take you up on that as I am pretty unfamiliar with adjusting the heims on the UCA to see what numbers I can change on my caster without ruining the possibility of alignment.
    Also I went to trucktoyz, once. The installed my top plates backwards on the U bolt flip I had them do. Took them a few days to do it as well so I never went back. Guy running the desk was nice enough but the mechanic doing the U bolt flip seemed really annoyed about having to do the job in the first place. Fixed the plates myself at home when I did the airbumps.
    vhinojosa4735 likes this.
  9. Mar 28, 2023 at 7:15 PM
    #69
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Curious how much angle the x-joint does. I've had my hands on a couple different +2 kits lately, and all of them reach mechanical bind off of the Uca uniball between 11.4"(total chaos) and then my Allpro kit binds at 12.1".
    SoonToBeOn39s likes this.
  10. Mar 28, 2023 at 8:59 PM
    #70
    vhinojosa4735
    Vince
    Corpus Christi, TX
    There’s not many shops in Texas let alone south Texas that know much about anything other than basic 3” kits or drop bracket kits. I’ve been dealing with and learning the long travel side of things for a while and have reached out and met some guys that are pretty knowledgeable in the Baja/race world. The adjustable uppers thing is tedious work, I put a +4.5 race kit on my wife’s truck and spent about 7 hrs fine tuning the truck on and off the alignment rack. Once I had it right it was super worth it, but man it was a bitch getting there. Lol
  11. Sep 5, 2023 at 12:26 PM
    #71
    Jadamjr
    Jadamjr Well-Known Member
    Jonathon
    Phoenix,AZ
    2017 DCLB TRD OR
    Any updates from anyone? How’s it working? Interested in this kit.
  12. Sep 6, 2023 at 10:03 PM
    #72
    Strekcorp
    Strekcorp Member
    Texas
    2019 Voodoo TRD Pro
    Magnuson TVS 1900
    I lost a few screws that hold in the rubber slappers, ordered a new bag of 50 for like 6.00. Other than that, has been great. No real complaints.
  13. Sep 7, 2023 at 1:05 PM
    #73
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    How's it ride and are you happy with how much lift you got?
  14. Sep 8, 2023 at 4:02 PM
    #74
    Strekcorp
    Strekcorp Member
    Texas
    2019 Voodoo TRD Pro
    Magnuson TVS 1900
    @TacoEspecial the kit does not determine the ride quality or lift. You lose your swaybar which is not a factor for me, but may bother others. For things that actually affect the lift or ride I think you should consider more of what shocks or springs you wanna run.
    I have Fox 2.5 extended travels with the remote reservoirs and DSC's all around. I am running 700lbs springs in the front and Icon RXT stage two in the back. "32" inch tires. The truck is essentially a glorified mid travel with the kit, but its nice. I adjusted my coil overs so that I gained about 2 3/4 inches up front and the icons have at least 3 inches in the rear. Its just a bit wider, gives more articulation and does not need fiberglass fenders. Ride is stiffer than stock and I feel more of the bumps in the road but thats all due to shocks/springs and the change to hiem joints, its not bad though.
    The kit itself is great IMO and honestly Camburg has some long wait times (if its a sale) to get a hold of customer service BUT they actually do follow up with you and have been really helpful and transparent about everything. I have heard really good things about JD Fab's kits (they have a 2.25 kit) and that seems like a more popular choice but I have always been a Camburg fanboy.
    TacoEspecial, lamjam and bhova like this.
  15. Dec 31, 2023 at 1:42 PM
    #75
    lamjam
    lamjam Well-Known Member
    Los Angeles
    2021 TRD Off road 4x4
    Any long term updates on this kit?
  16. Feb 20, 2024 at 8:15 PM
    #76
    atmullis
    atmullis Member
    Alex
    Denver
    2015 DCLB
  17. Sep 17, 2024 at 8:22 PM
    #77
    technicoloraudio
    technicoloraudio Well-Known Member
    Evan
    Cary, NC
    MBM 2021 TRD DCSB Sport
    Fox Performance Elite 2.5's with 650lb eibach springs and deaver stage III's, URD Y-pipe, Desert Does It all around, ARB Twin, RCI aluminum skid plates, Westcott sliders, UpTop Alpha roof rack, SSO slimline plate front bumper, BAMF hgih clearance rear bumper, hella gummy bears (strictly Haribos, none of that weak-ass Trolli bullshit).
    I just ordered this kit and wondered if anyone had any experience with fitting +2.25” 934 axles into a +2” LT kit?
  18. Dec 30, 2024 at 9:51 PM
    #78
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    bump, wanting to know what more people have to say about this kit (if anyone else has bought it recently)
