******Camburg UB install question ----- in middle of install******
Discussion in 'Suspension' started by Dampahee, May 23, 2020.
  1. May 23, 2020 at 5:03 PM
    Dampahee
    Dampahee [OP] Well-Known Member
    So Cal
    2019 TRD Off Road
    Fox Factory 2.5 extended travel w/DSC Eibach 650x14 springs Fox Factory 2.5 x 12 in smoothies with rr and DSC / Accutune Adventure tune Archive Garage shock relocation Archive Garage hammer hangers with 3.6" shackles Archive Garage high clearance cross bar Deaver Expedition u402 stage1leaf pack Camburg Racing Uniball UCA's Total Chaos Gusseted Spindles Marlin Crawler HD LCA/cam tabs Frame Brace gussets @weldstaco front diff reinforment kit Wheelers u-bolt flip kit with super-bumps Crown performance SS 24 in extended rear brake lines SS extended front break lines Exhaust re-route mod Dirt King Cab Mount Relocation OV Tune-91 Performance Nitro 5.29 Gears ARB Front Locking Differential ARB High output in board compressor Slee On-board compressor mount Blais Bros Taco differential breather mod Schmellfab 12.5° sliders with kick out RCI steel IFS skid RCI steel transmission skid RCI steel T-case skid RCI LCA skid BAMF Rear differential skid Relentless Fabrication hybrid front bumper Relentless Fab High Clearance rear bumper ATHF rear fender supports SOS performance rear disc brake conversion Trimmed Fenders 2.5" Softopper TRD Heritage grill RFT Raptor lights Morimoto XB headlights Baja Designs amber S2 flush mount chase lights Baja Designs S8 30 in lightbar Cali Raised Relay Mount Cali Raised cubby switch mount Smittybuilt X20 10 k winch Factor 55 Fairlead Factor 55 Flatlink E Factor 55 Flatlink Ropeguard Tandem Off Road Manor winch solenoid mount 1.25 inch Spidertrax wheel spacers 17x9 Ultra Wheel x103 beadlocks 35/11.5/17 Nitto Trail Grapplers Fend-X Wheel Liners Clazzio leather seat covers Taco Garage DMM Mount Taco Garage Anytime Front/Rear Camera MESO Customs Chrome Delete MESO Extended fuse cover AVS in channel low-profile wind visors Kicker CS tweeters, 6x9, 6.5's Kicker Key amp Kilmat sound deadening
    I'm going to install my uca's this week and was wondering if I have to grease using the zerk fittings on initial install, or is lubimg the inside of the fitting adequate initially?
  2. May 23, 2020 at 5:05 PM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    You should grease them. it won’t be bad if u don’t have the gun but grease everything before install.
    Dampahee[OP] likes this.
  3. May 23, 2020 at 5:21 PM
    Dampahee
    So Cal
    2019 TRD Off Road
    Thanks man. I have the grease gun already, just wanted to make sure I'm not over greasing since I'm greasing them before I install them.
    Jason TRD OR likes this.
  4. May 25, 2020 at 11:45 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Follow the Total Chaos UCA instructions (it's under their vendor sub heading). Make sure the main cross shaft is loose when you pump in the grease, and then torque it when you are done. This will keep from destroying the bushings.
    whatstcp likes this.
  5. May 25, 2020 at 12:11 PM
    Dampahee
    So Cal
    2019 TRD Off Road
    Thanks! Those are the videos I was looking at for install/maintenance. Going to tackle this project tomorrow.
  6. May 25, 2020 at 12:13 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It doesn’t matter either way. I would grease them “manually” when installing them.
  7. May 25, 2020 at 12:16 PM
    CanadaToy
    Greg
    Toronto
    They have a great install / coilover install vid on youtube... 14 minutes per side... tackling mine this weekend... budgeting 2 hours LOL
    Dampahee[QUOTED][OP] likes this.
  8. May 25, 2020 at 12:16 PM
    Dampahee
    So Cal
    2019 TRD Off Road
    that's what I've seen in all the install videos I've seen. Greasing the inside of the bushings upon assembling the UCA. Thanks for the confirmation.
    EatSleepTacos[QUOTED] likes this.
  9. May 25, 2020 at 12:17 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Make sure you grease the outside face of the bushing too.
  10. May 25, 2020 at 12:18 PM
    Dampahee
    So Cal
    2019 TRD Off Road
    Good luck! I was going off the TC install vid since they're the most similar to my Camburgs I just purchased. Hoping all goes smooth. Installing tomorrow, new tires come in Wednesday, mount tires and alignment Thursday Morning.
  11. May 25, 2020 at 12:19 PM
    Dampahee
    So Cal
    2019 TRD Off Road
    Are you sure? In the TC install vid they say not to do this as we don't want movement of the bushing.
  12. May 25, 2020 at 12:22 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The outside face, where the washers rest against the bushings in the uca.
    Not the outer part of the inside of the bushing. (That’s confusing)
  13. May 25, 2020 at 12:23 PM
    Dampahee
    So Cal
    2019 TRD Off Road
    And I'm giving myself the whole day lol I'm a newb to working on suspension haha
  14. May 25, 2020 at 12:26 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  15. May 25, 2020 at 12:29 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    ... ings.
  16. May 25, 2020 at 12:32 PM
    Dampahee
    So Cal
    2019 TRD Off Road
    Ok, so on initial assembly of the uca, but upon installing on vehicle before running the rod back through. I think I got it lol
  17. May 25, 2020 at 12:33 PM
    Dampahee
    So Cal
    2019 TRD Off Road
    Haha, I like simple pics lol
  18. May 25, 2020 at 12:34 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    When the arm is installed and you grease it, some will seep out the sides and hit that area. Didn’t want them going in bone dry.
  19. May 25, 2020 at 12:40 PM
    Dampahee
    So Cal
    2019 TRD Off Road
    Got it. I think you've pretty much cleared up any confusion I had. Ill grease those areas and I'll skip out on using the zerk fittings to grease initially, and just leave that for the routine maintenance.
  20. May 27, 2020 at 5:35 PM
    elgringoloco
    elgringoloco Well-Known Member
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Phrasing!
