Camburg UCA’s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stuntman79, Feb 21, 2022.
  1. Feb 22, 2024 at 9:26 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Confusing to some. Not all. Might try and read the posts, in this thread, from the person you quoted.
    Increasing caster at the UCA, means moving the wheel back. Toward the cab mount and rear wheel well.
    For large tires, caster should be gained by moving the LCA away from the cab mount. That's why SPC UCA is the best in this department, it has near unlimited caster and camber adjustability.
    toku58 and cwk84[QUOTED] like this.
  2. Feb 22, 2024 at 9:32 PM
    cwk84
    cwk84 Active Member
    2019 TRD OFF-ROAD
    Lift and tires
    I formerly apologize for not having read more carefully.
    Would you happen to know a shop in SoCal who knows how to adjust them? I’m in the process of upgrading to a larger size tire and Dobinsons suspension. The SPCs are the only ones I’d consider but I’m worried that the run-off-the-mill alignment shop won’t know how to adjust them.
    Superdave1.0[QUOTED] likes this.
  3. Feb 22, 2024 at 9:46 PM
    Superdave1.0
    SoCal
    Well, some here would recommend me. I've lifted about 100 Tacoma/4runners at this point. I work at a shop in Huntington, I do alignments there. You could bring it there.
    Or 88 rotors, RPM garage, Sibi built, etc could get you dialed in for tire clearance and alignment.
  4. Feb 22, 2024 at 10:03 PM
    TN1000
    TN1000 Well-Known Member
    2018 metallic silver TRD OR
    Work in progress
    What garage are you at in Huntington? Camburg?
  5. Feb 23, 2024 at 6:55 AM
    Superdave1.0
    SoCal
    TopLine
    TN1000[QUOTED] and cwk84 like this.
  6. Mar 8, 2024 at 10:07 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Sorry I haven't been around for a while.
    Before you chime in on something? Please go back a actually read what led up to the post. Or at the very least read post #11.
    Higher Caster UCA is a Terrible idea!!
  7. Mar 21, 2024 at 8:33 PM
    TN1000
    Work in progress
    I'm curious about everything you said in regards to offset. Is all that true with 0 offset or even -10, or is it in regards to stock which is +25 offset?
  8. Mar 22, 2024 at 7:21 AM
    YotaHead858
    YotaHead858 Well-Known Member
    San Diego, CA
    2023 TRD OR
    King Shocks Camburg UCA's
    I'll stray away from the topic of suspension geometry and let the more seasoned guys continue.. lol
    I'm running King's 2.5 EXT's. With that, I'm running Camburg UCA's with the x joint so no uniball on mine. What I like about them is that they're sealed units.
    Additionally, I have their dust cap which keeps dirt out. (I think newer Camburg UCA w/ uniball have options for dust caps as well.. Someone correct me if i'm wrong on this)
    Uniballs aren't bad though, just need to keep up with maintenance and keep them clean. I'm running them on my FJ Cruiser and have and any issues or squeaks for the past 3 years of having them on.
    Superdave1.0 likes this.
  9. Mar 22, 2024 at 7:22 AM
    YotaHead858
    San Diego, CA
    2023 TRD OR
