Camburg uca install help
Discussion in 'Suspension' started by IRISHDEVIL, Oct 22, 2008.
  1. Oct 22, 2008 at 12:46 PM
    IRISHDEVIL
    IRISHDEVIL [OP] Well-Known Member
    i just got my camburg uca's and i dont want to bent thr pinch molding. isnt there an easier way?
  2. Oct 22, 2008 at 12:57 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Bend it to get the bolt out, reinstall the bolt from the other side when reinstalling, and bend the metal back. Don't worry -- it doesn't feel pain. :)
  3. Oct 22, 2008 at 2:24 PM
    IRISHDEVIL
    If toyota was to change these out they would not be bending the pinch to get it out. Im wondering if i should just get new bolts and reverse them when i put the new ones in
  4. Oct 22, 2008 at 3:18 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    I thought about reversing them but decided against it -- just in case the nut loosens and the bolt falls out -- paranoia at its finest.
  5. Oct 22, 2008 at 5:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The only other way to install them is o jack the body off the frame to give slearance. Nothing will be hurt by bending the little bit of steel. :)
