Camburg UCA question
Discussion in 'Suspension' started by phil12382, Dec 8, 2014.
  1. Dec 8, 2014 at 10:37 AM
    phil12382
    phil12382 [OP] Active Member
    Phil
    Cols,OH
    08 4x4 dbl cab trd off rd
    Bilstein 5100's all around with OME 885s in front . 265/75/16. 5k hid, Fog 3k. Anytime fog light mod. Grillecraft upper and lower. Firestone airbags. Daystar Cradles. Illuminated 4x4 switch. Scan Guage II. LR UCA.
    wondering how hard or easy it is to just buy the camburg UCA without the ball joints already pre pressed in. I have a actually press here at work and also a ball joint press kit. It would be with the moog ball joints
  2. Dec 8, 2014 at 11:07 AM
    KayStrait
    KayStrait Camburg Girl
    Kayla
    Huntington Beach
    '98 Desert Dune SR5 4Runner
    Those UCAs are made to fit a FACTORY Balljoint. So if you are trying to press a moog ball joint in, you will need to machine it down to make it fit in the arm without damaging it.
  3. Dec 8, 2014 at 2:23 PM
    phil12382
    Phil
    Cols,OH
    then from the factory does camburg machine the arm down to fit in the moog joint?
  4. Dec 8, 2014 at 3:03 PM
    KayStrait
    Kayla
    Huntington Beach
    No we do not machine moog balljoints, we recommend you either use your stock balljoint, or find a shop that will machine those aftermarket balljoints to fit in the arm. There is also one of our dealers, Wheelers Offroad that sells our arm with balljoints already pressed in. I would check them out.
  5. Dec 8, 2014 at 3:13 PM
    phil12382
    Phil
    Cols,OH
    that's where I was looking and where I have bought all my lift from. So how are they able to press the moog ball joints in without machine down the joint. I work at a Toyota dealership so im just curious to how hard it really can be when wheelers already sells them already pre installed
  6. Dec 8, 2014 at 3:23 PM
    KayStrait
    Kayla
    Huntington Beach
    They are machining the balljoints down, all aftermarket balljoints are inconsistently produced which make them larger than the stock balljoints. The MOOG balljoints specifically, have ridges around the balljoint that you have to machine down to smooth to fit in our ucas. Do NOT try and force press an aftermarket balljoint into our uca without machining it down a little first.
  7. Dec 8, 2014 at 3:37 PM
    phil12382
    Phil
    Cols,OH
    awesome thank you for the info much appreciated.
  8. Dec 18, 2014 at 8:51 PM
    Andrewb13tcb
    Andrewb13tcb Silver Surfer
    Andrew
    WA,ID,TX
    -4.56 Gears Front & Rear -Toytec Coilovers W/ Bilstein 5100 Shocks Front & Rear -ARB Air Locker In Rear -ARB Air Compressor -Marathon Seat Covers -Weathertech Floor Mats -Leer Canopy -K&N Intake -Flowmaster Exhaust -Rhino Lined Bed -Alpine Type R Speakers Front & Rear -Alpine Head Unit -Alpine 400 Watt Amp -Custom One Piece Headlights -Suntek Tinted Windows (Lifetime) -URD O2 Sensor Retarder -Billet Rear Window Pivot Much More To Come
    Sorry to high jack this thread but I'm looking at Camburg UCAs and the Fox Racing 2.5 Factory Kit you guys offer and it says wheels with max 4.5 back spacing. Well the wheels I want are 17x9 with 1mm offset and 5" back spacing. I wanna run 255/80R17 tires. Are the wheels going to rub on the UCAs or what?
  9. Dec 24, 2014 at 11:30 AM
    KayStrait
    Kayla
    Huntington Beach
    Yes, with that backspacing it does not give much room, so there will be rubbing. The size of the wheel doesn't matter as much as the actual backspacing. That determines how far in the wheel will sit. You can run those but you will either have to live with rubbing or run a wheel spacer. Or of course get a wheel with no more than 4.5" backspacing :)
  10. Dec 24, 2014 at 11:42 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    4.5" BS here. That's really about as much as you are going to want to run, it's also probably the BS that most out there would recommend on this truck if you are not going LT.
  11. Dec 24, 2014 at 12:05 PM
    Andrewb13tcb
    Andrew
    WA,ID,TX
    Alright. Good to know. What is it that rubs by the way? The tire or the wheel? I have no rubbing issues with this Backspacing now but I also run 255s. I like the fuel wheels but they all seem to be 5" Backspacing. No 4.5s
  12. Dec 24, 2014 at 2:08 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's mainly the tire. I have never had an issue with the wheel itself rubbing but then again I have a second gen. You might want to check measurements and find out if 5" BS will be ok if you are dead set on getting a set of the fuel wheels.
  13. Dec 24, 2014 at 2:12 PM
    Andrewb13tcb
    Andrew
    WA,ID,TX
    Right on I appreciate it
