Camburg UCA - Set caster at around 2.5 or 3.0 deg?
Discussion in 'Suspension' started by parkp81, Oct 14, 2014.
  1. Oct 14, 2014 at 7:53 PM
    parkp81
    parkp81 [OP] Well-Known Member
    Fil
    Southern California
    delete
  2. Oct 19, 2014 at 8:39 AM
    abcangelo
    abcangelo Well-Known Member
    Angelo
    Lakewood, CA
    14 TRD Sport 4X4
    I'm on the same boat here. Drives a little twitchy, pulls on uneven surfaces. It was suggested I change out my UCA's; I have a 3" lift and just ordered a set of the Camburg uniball UCA's. Should have them installed within the next few days so we'll see what happens.
  3. Oct 21, 2014 at 4:34 PM
    abcangelo
    Angelo
    Lakewood, CA
    14 TRD Sport 4X4
    Well hope Camburg knows what they're doing because I have no idea what degree to ask for. I'm having it installed there in Huntington Beach and they're also taking care of the alignment. So we'll see. Just waiting for the sleeves guess they're backordered.
  4. Nov 14, 2014 at 7:39 AM
    Taco Diver
    Taco Diver Active Member
    Josh
    FW,TX
    06 BSP Sport DCSB
    Fox 2.0, Icon AAL, All Pro IFS Skid & U bolt flip kit, dash light mod, Grillcraft grill, rear diff breather mod, ECGS bushing install, SCS Stealth 6 Gunmetal with Falken SL 265/70-17
    Any updates? I have similar ride characteristics and just bought the same UCAs. Hopefully I'll be installing them this weekend.
  5. Nov 14, 2014 at 9:10 AM
    Taco Diver
    Josh
    FW,TX
    06 BSP Sport DCSB
    Dang that seems a bit strange. Hopefully you get that worked out. Thanks for the response!
  6. Nov 16, 2014 at 4:55 AM
    abcangelo
    Angelo
    Lakewood, CA
    14 TRD Sport 4X4
    Well I got them installed and had the alignment done. It's been about more than a week or so... Definitely a better ride, more stable, corrected, if not, minimized everything I mentioned before. No printout available, "alignment done manually" but I did end up having to remove my mud flaps completely. In reverse and turned hard over I get some minor rubbing, but hey I am running 33's. Other than squeaking from the UCA's in the forecast unless properly maintained every so often--keeping the uniball nice and lubed--I'm pretty satisfied with them and they look pretty cool.
