Camburg UCA squeak
Discussion in 'Suspension' started by DNG, Dec 13, 2011.
  1. Dec 13, 2011 at 9:01 AM
    DNG
    DNG [OP] Well-Known Member
    Orange County, CA
    White 01 DC PreRunner
    I have an annoying squeak coming from my left UCA. I did my research and tried lubing the uniball and bushings, and greased the nipples. No luck. There was a bit of rain these last couple days and the squeak went away, but now that it's dry again, the squeak is back. Any suggestions?
  2. Dec 13, 2011 at 9:05 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    How long have you had them? Uniballs will start to squeak. If you want quiet you would have wanted to stay with an upper ball joint
  3. Dec 13, 2011 at 9:06 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I had to give mine a few pumps every day for like 3-4 days until they were good???? I have the ball joint one's and they should be maintenance free but they still need lubbing! As long as the bushings don't looked damaged, I'd just keep giving them more for a few days!
  4. Dec 13, 2011 at 9:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Going on 4+ years with my Total Chaos UCA's, and they are still nice and silent....
    JMY24 likes this.
  5. Dec 13, 2011 at 9:07 AM
    LBPtaco
    LBPtaco Swab
    Winter
    California Maritime Academy
    06 PreRunner TRD
    Total Chaos, SAW, Allied, Light Racing, Dakar, Billstein, Fox, URD, JBA, Demillo, Downey, Cooper, American Racing, B.A.M.F., Alpine, Ghetto Fab...
    I've had the same problem. I use http://boeshield.com/ on the uniball and it seems to work pretty well. Although at this point everything else in my truck squeaks and rattles so much I don't really notice any more...
  6. Dec 13, 2011 at 9:25 AM
    Cr250jumper
    The moon
    50 shades of tan©
    I think AZ is pretty nice to them. The east coast and Cali guys complain about squeaking pretty quick
  7. Dec 13, 2011 at 9:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im not easy on them. Ive had wet concrete dry on them, had them submerged in a lake for 5 + hours, and had mud on them. I dont wash them very often, and lube them once a year....if that.
  8. Dec 13, 2011 at 9:57 AM
    DNG
    Orange County, CA
    So is it the uniball that's squeaking or the polyurethane bushings?
  9. Dec 13, 2011 at 10:57 AM
    LBPtaco
    LBPtaco Swab
    Winter
    06 PreRunner TRD
    in my case (with 'burgs) its the uniball. i grease the bushings once a year (ish) and i lube the uniball whenever it squeaks too much.
  10. Dec 13, 2011 at 11:00 AM
    sprocketdog
    sprocketdog Well-Known Member
    Halifax Pa
    05 Taco 96 Taco 06 TSX 94 extra cab Hilux
    DR coilovers, Camburg UCAs, Dakar rear springs, Bilstien 5150s, Demello sliders, rear plate bumper w/ swing gate, and alot more mods. [IMG]http://i1216.photobucket.com/albums/dd368/sprocketdog1/059.jpg[/IMG]
    I use Klotz assembly lube and let it soak in over night every so often.
  11. Dec 13, 2011 at 11:06 AM
    Cr250jumper
    The moon
    50 shades of tan©
    Hard to tell without being there. One thing is you do not want to lube a uniball with a "wet" lube. I use a dupont teflon wax stuff that is "dry" and it keeps dirt from sticking to the lube
  12. Dec 13, 2011 at 12:09 PM
    DNG
    Orange County, CA
    It's hard to tell myself. I can hear the squeaks going over small bumps, but I can't recreate the sound by pushing down on my truck. I tried using teflon based lube, but with no luck.
    However, the rain seemed to do the trick and made the squeak go away for a bit. Any ideas on this?
  13. Dec 13, 2011 at 12:23 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    undo the uni ball from the spindle and source the location of your squeak
  14. Dec 15, 2011 at 10:15 AM
    onepremiere
    onepremiere I Tinker
    Jeff
    Left Coast
    You're correct, however. You can use a wet lube, let it pool up at the uniball, let it sit over night. Then wipe the top and bottom clean.
    Wet lube is sometimes needed for pesky uniballs.
    If that doesn't work, check to be sure all your spacers are in good condition, if they edges are damaged, it can tear the teflon liner.
    What are you running for a suspension lift? On coilovers, sometimes the rod-end bearing will make noise. That bearing is a smaller version of what is in your UCA.
    After about 60K miles on the arms without ever greasing the UCA Bushings, I started to get this rubber noise when the suspension cycled. Sound was similar to stretching a balloon. All they needed was some grease. I took them apart added grease, sound was gone!
    I put mine through hell, and they only complained when they were dry. (After Rain or Dry Weather)
    All that dirt was on my truck for a month. (Working in the mountains during the winter. :D)
    -Jeff @ Camburg
  15. Dec 15, 2011 at 10:21 AM
    Cr250jumper
    The moon
    50 shades of tan©
    My passenger side lower spacer (spindle adapter one) is not in good condition. I bent it installing and fixed it so it doesnt grind but now it has a tiny gap and lets dirt in :( It was my first lesson learned, do not tighten the UCA on to the spindle with the suspension drooped
  16. Dec 15, 2011 at 10:30 AM
    onepremiere
    Jeff
    Left Coast
    Ill admit, that happened to me, before I worked for Camburg. Well, I didn't actually do it myself, my buddy was working on one side, I was working on the other.
    I'd get a new spacer! You're going to cut down the life of those bearings.
    -Jeff
  17. Dec 15, 2011 at 11:02 AM
    Cr250jumper
    The moon
    50 shades of tan©
    ^How much is it? Its the part that looks like this
  18. Dec 15, 2011 at 11:30 AM
    onepremiere
    Jeff
    Left Coast
    $50 Retail, Tacoma World Member = $45
  19. Dec 15, 2011 at 11:38 AM
    Cr250jumper
    The moon
    50 shades of tan©
    Awesome thanks thats not bad at all. I will have to order a new one soon as I can
  20. Dec 16, 2011 at 2:56 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Does the squeek/qreek happen if you are stopped and steer left and or right?
    I have/had the same issue with mine only when I turn the steering wheel a few times while stopped, I was told my Camburg to go take them offroad and apply Tri-Flow with PTFE in it afterwards. I still get sqeeking and qreeking but not nearly as much. I have recently been told that this is a usual complaint using the Camburgs.
