Camburg UCA squeak
Discussion in 'Suspension' started by DNG, Dec 13, 2011.
  1. Feb 10, 2012 at 11:00 AM
    V-TRAIN
    V-TRAIN Well-Known Member
    N. CACKALACKY
    08 TRD SPORT LONG BED
    DEMELLO ROCK CRUSHER SLIDERS, PIAA LIGHTS, TSB 4 LEAF PACK, CBI OFFROAD REAR BUMPER LINEXED, CBI OFFROAD FRONT BUMPER LINEXED, REAR 5100's, 1.5" TSB AAL, ICON EXTENDED TRAVEL COILOVERS @ 3", TOTAL CHAOS UCA's, HELLA MICRO DRIVING LIGHTS, IPOD INTERFACE, THULE ROOF RACK, UWS SLIM LINE BLACK TOOL BOX, 17" BBS RD TRUCK WHEELS, GOODYEAR WRANGLER DURATRAC IN 285/70/17
    i have the same problem from time to time with my tc uca's. when it gets wet it stops. it is the bushings rubbing up against the washers. i stopped mine by getting some triflow (the same stuff you use on the uniball), and applying it at both sides of the grey uca arm, where it meets the washers (in 4 points). apply at the top of the crack and let it run down. soak it some, after a day or 2 of driving, it will work its way down and the squeak will go away. it is a easy fix. i bought new bushings for mine and was going to replace them. i was like, hold on, if it stops when wet then
    the triflow should take care of it. i have about 50,000 on my ucas.
  2. Feb 10, 2012 at 11:01 AM
    V-TRAIN
    N. CACKALACKY
    i have plenty of grease in mine also.
  3. Mar 23, 2013 at 8:59 AM
    radiagojr
    radiagojr Member
    Rene
    Hayward,Norcal
    2012 Tacoma 4x4
    Tire 265/75/17 HD series rims Icon extended travel coil over icon add a leaf camburg uca painted all emblems and grill black
    Dng did you ever solve you squeaking problem.i have been having the same problem and I only had this camberg uca for 8 months. Sound goes away when it is raining.
  4. Apr 13, 2015 at 3:50 PM
    Vanhuette
    Vanhuette Well-Known Member
    Winnipeg, Manitoba
    2006 double cab TRD sport
    same thing with the TC UCA's. goes away when its raining, then comes right back. I was told it was the uniball so I've been using dry lube on it, but literally works for 24 hours or less before the squeak comes back (if it was gone at all). Could be the bushings, i didn't try to lube those so ill try that now.....
    Ive read that you're not supposed to use wet lube/grease on them. Any input on that would be great
