Camburg UCA squeak
Discussion in 'Suspension' started by PortRoyal91, Nov 15, 2021.
  1. Nov 15, 2021 at 6:55 PM
    PortRoyal91
    PortRoyal91 [OP] Well-Known Member
    Christ
    08 access cab prerunner
    Decked, RCI Bed rack, Leveling Kit, 33”
    Alright TW, I just do not know where to go from here.
    I have the camburg ball joint (not uniball) UCA’s and I’ve must’ve greased these damn things 10 times on the bushings and 3x on the ball joint Zerg fitting.
    They will not stop speaking, it’s beyond obnoxious at this point.
    Ive used the Lucas red n tacky grease and just switched to the green stuff to see if that did anything. Nope, still not a damn thing.
    I’m about to take these off and sell them for something else if I cannot figure it out.
  2. Nov 15, 2021 at 7:02 PM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Do you loosen the UCA nuts/bolts before pumping? There is a procedure you need to follow to grease the pivots (not the bj)
  3. Nov 15, 2021 at 7:03 PM
    PortRoyal91
    Christ
    Yup, I loosen em and pump enough in there to see it expand then tighten it back down.
  4. Nov 15, 2021 at 7:05 PM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Huh. That’s my only guess. Mine have been quiet for 30k and I seldom grease them at all.
    Hope you get some more ideas, good luck
  5. Nov 15, 2021 at 7:24 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
