Camburg UCA's Hitting Coils on Ext Travel Coilovers??
Discussion in 'Suspension' started by Sublime, Mar 9, 2012.
  1. Mar 9, 2012 at 10:31 AM
    Sublime
    Sublime [OP] Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Hey guys, spoke with Scott at Camburg to confirm a couple things.......
    I basically wanted to confirm that the ball joint UCA's I have from them will work with an ext travel coilover like Icon. Wanted to see that they'd provide the same amount of droop as their uniball and if so, would they hit the coils like the 1.25" uniballs do?
    "With our ball-joint upper arms since we change the angle of the ball-joint, it allows for more travel using extended length coilovers without any kind of binding. With those coilovers you will get the same amount of wheel travel ball-joint vs uniball. It's rare for our 1.25" uniball uppers arms to just touch the coils on droop. Many variables contribute to that situation, what coilover, alignment specs, other parts installed, and the actual truck. You'd be surprised how different two trucks of the same year can be."
    He then went on to say he was unaware of their uca's hitting the coils of Icons or anyother brand, yet I'm pretty sure this has been happening for a while now!
    He said their coilovers will pull 10.5-11" of travel with out hitting the uca....is this safe for a 4x4? Would the Icon's at 9.5-10" travel be better?
    Thoughts?
  2. Mar 9, 2012 at 10:34 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    The camburg 1.25 can and probably will hit. Out of 3 trucks I've known with those uppers 2 hit the coilovers
  3. Mar 9, 2012 at 10:39 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    That's what I thought.....I knew Cliff's touched and he had that combo at one point. So the bj's allow as much droop, they'll hit?!?!
  4. Mar 9, 2012 at 10:40 AM
    PLC721
    Patrick
    Chandler, Az
    Uhm I think it's the size being a 1.25" that causes them to hit...but I could be wrong! Lol
  5. Mar 9, 2012 at 11:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Correct. The 1.25's hit the coils, unless the coils are turned "just right". 1" and BJ UCA's dont hit the coils.
  6. Mar 9, 2012 at 11:34 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Ok, that makes sense! What's up with burg coilovers pulling 10.5-11" of travel? Crazy!
  7. Mar 9, 2012 at 11:38 AM
    PLC721
    Patrick
    Chandler, Az
    I actualy find that hard to believe. Lol
  8. Mar 9, 2012 at 11:42 AM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Encinitas/San Diego
    agreed! :anonymous:
  9. Mar 9, 2012 at 11:43 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Hell ya, AP LT pulls 12" on 4x4!
  10. Mar 9, 2012 at 11:43 AM
    PLC721
    Patrick
    Chandler, Az
    Why hello Landon :spy:
  11. Mar 9, 2012 at 12:12 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Can't remember, does the spring rotate when you rotate the perch with the spanner?
  12. Mar 9, 2012 at 12:19 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Ohhh F! So maybe I should get the standard travel?
  13. Mar 9, 2012 at 12:24 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    limit straps. problem solved... or just stick with the 1" version... nobody here needs a bigger uni than that
  14. Mar 9, 2012 at 12:24 PM
    Supermoto
    Landon
    Encinitas/San Diego
    Anyone ever seen or heard on a coil, shock or UCA breaking from them touching at droop?
  15. Mar 9, 2012 at 12:49 PM
    KenLyns
    Belly of the Beast
    Ask Camburg if their balljoint UCAs use the same bearing cup as their 1.25" uniball UCAs. If the balljoint bearing cup is smaller, it won't hit the spring.
  16. Mar 9, 2012 at 12:57 PM
    Relik
    Relik Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    I would try and rotate the spring. I remember I had a coil touching problem with my coils although they are different. Toyota recommends that the spring perch be oriented so the bottom part of the coil starts in the back left pointing direction for both sides. Meaning the start of the coil be @ 7-8 o'clock based on the truck's orientation. I then corrected it and no touching. This might obviously only apply to stock coils, but the principle of why it is done might be the same.
    Can you rotate the spring on the ext travel CO when off? that might just move the coil enough to leave the void in the coil when it reaches the position where it hits...
  17. Mar 9, 2012 at 1:07 PM
    KenLyns
    Belly of the Beast
    Rotating the spring 90 deg won't affect ride height by a noticeable amount. The thread pitch on the shock body is too fine for that.
  18. Mar 9, 2012 at 1:26 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Said the cup was a little smaller but the TC 1" does it too! That's just stoopid and could cause a gash in the spring! Guess strapping it would work but seems stoopid too!
    Whatever! :rant:
  19. Mar 9, 2012 at 1:31 PM
    KenLyns
    Belly of the Beast
    1" TC shouldn't for most people. My All-Pro 1.25" doesn't touch the Icon ET coil, either. I think the condition is more prevalent with the Camburg 1.25" UCA because of its specific geometry (amount of caster, degree of uniball "tilt", etc.).
  20. Mar 9, 2012 at 1:35 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Strapping is a good idea on any suspension if its going to go full droop frequently. You should not be resting the weight of your suspension on ball joints, uniballs, and/or shocks
