Camburg Upper Arm Group Buy "FEELER"
Discussion in 'Group Buys' started by Downsouth Motorsports, Jul 26, 2013.
Thread Status:
Not open for further replies.
  1. Sep 28, 2013 at 9:46 PM
    #181
    DESRTRNNR
    DESRTRNNR Well-Known Member
    Phoenix
    13 DCSB TRD off road 4x4
    mine werent threaded either.. the guy that installed them had the threading die and did it for me
  2. Sep 28, 2013 at 9:51 PM
    #182
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    Thanks that's what I am going to do tomorrow can't wait any longer.
  3. Sep 29, 2013 at 6:29 AM
    #183
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    The zerks are self tapping. It says in the directions.
  4. Sep 29, 2013 at 9:29 AM
    #184
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    Ok thanks going to read instructions again.
  5. Sep 29, 2013 at 5:54 PM
    #185
    DESRTRNNR
    Phoenix
    who reads instructions.. if it was important it would have been in the pictures
  6. Sep 30, 2013 at 9:14 AM
    #186
    Downsouth Motorsports [OP] Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    Hey guys, it looks like you have it handled, but I did call Camburg to verify and the zerks are self tapping.
    This is from the instructions...
    Using a 1/4” wrench install the self tapping zerk fittings into the Camburg arms
  7. Oct 24, 2013 at 11:23 PM
    #187
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    Ran into another problem. Driver side making a loud humming noise coming from the drivers side thought t was coming from the rack and pinion but took it into Toyota and they said nothing is wrong, had already taken in for wheel alignment after Camburg UCA installed. So next step thought maybe short on grease, so bought some of the Camburg grease and greased up the 4 zerk fittings. Still making a loud humming sound while turning the steering wheel, when the truck is at a stop and when moving less then 10 mph. Has anybody come across of this problem. I am running ToyTec Ultimate Lift Kit, KM2's 285/75/16 on TRD TX Pro Fake Bead Lock Rims. Had no humming sound while running stock UCA arms.:confused:
  8. Oct 25, 2013 at 7:26 AM
    #188
    Lakeside, Ca. 92040
    I haven't heard of this issue, I would recommend you contact Camburg, see what they think and then possible take it to a reputable shop and have them inspect it.
  9. Oct 25, 2013 at 10:39 AM
    #189
    Thetequilaworms
    Thetequilaworms Carlos@Camburg.com Vendor
    Carlos
    Huntington Beach
    That uniball might need some lube. We recommend you use high temp, dry PTFE lubricant. Triflow is a good one to use. Lube the uniball, give the wheel a few turns and drive it around a little so that the lube gets into the lining and then wipe any excess grease off.
  10. Oct 25, 2013 at 12:06 PM
    #190
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    Thanks will try it this weekend.
  11. Oct 25, 2013 at 12:11 PM
    #191
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Finally found time to install my Camburg's..... I'm loven them!!
  12. Oct 25, 2013 at 4:59 PM
    #192
    Thetequilaworms
    Carlos
    Huntington Beach
    Sounds good, feel free to send me an email if you have any other questions!
    Carlos@camburg.com
    same applies for anyone else with questions about their UCAs
  13. Oct 25, 2013 at 8:46 PM
    #193
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    Tri flow lubricant is amazing thanks
  14. Oct 26, 2013 at 6:26 PM
    #194
    Thetequilaworms
    Carlos
    Huntington Beach
    Right on, glad it worked out for ya.
  15. Oct 28, 2013 at 7:12 AM
    #195
    Lakeside, Ca. 92040
    I didn't even think about it possibly being the uni ball by the way you described it.
    Glad it worked out.
  16. Nov 3, 2013 at 2:03 PM
    #196
    JoeySauce
    JoeySauce Well-Known Member
    Joe
    Eagle PA
    11 DCSB
    I had this exact same problem, had my mechanic pack in more lube while i tured the wheel from one extreme to the other. seems to have solved the problem. been noise free for about a month now
  17. Dec 12, 2013 at 10:15 AM
    #197
    octoyotaco
    octoyotaco Well-Known Member
    C
    Orange County
    Any more group buys on these anytime soon?
  18. Dec 12, 2013 at 11:45 AM
    #198
    Lakeside, Ca. 92040
    nothing as of now.
Thread Status:
