Camburg vs tc
Discussion in 'Suspension' started by FLAtacoma05, Nov 7, 2009.
  1. Nov 7, 2009 at 7:11 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    I have recently discovered that, it stings at first, then numbness.
  2. Nov 7, 2009 at 7:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I know....:)...
  3. Nov 7, 2009 at 7:22 PM
    FLAtacoma05
    FLAtacoma05 [OP] Well-Known Member
    Wes
    Crestview, FL
    2005 BSP Prerunner DBL Cab
    toytec spacers body lift 315/75/16
    its clear idk what im talking about people told me to register on here and people wouildbe glad to answer or help out with any issues im having.
    im not familiar with suspension components and what the do individually. im running a toytec 3" leveling kit with AAL and a 3" body lift with 35s.
    Its a pretty rough ride so i wanted to smooth it out with spindles (heard they ride just as good or better then stock ride) and coilovers. From what i understand that will give you 7" max lift in the front...
    My question is what can i put in the back to level this out?
  4. Nov 7, 2009 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats alot of lift. Get the spindles, and some CO's and UCA's. Set the CO's low....maybe an inch of lift. Then, get an 2.75" OME/Dakar AAL from Wheelers, and maybe a 1" block. If you want to go higher than that, I cant help.
  5. Nov 7, 2009 at 7:32 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    Dude,
    Listen to Chris. He has helped a lot here about suspension. Most disagree with you because what you are doing is not safe and not functional at all.
    PM GotLift37. I think he was running 37" before his truck got stolen.
  6. Nov 8, 2009 at 2:23 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    You can set your coilovers to what ever height you want, just make sure you have adjustable uca's to correct your alignment. I already had that headache. I recommend Icon's uca's because they are a hell of a lot easier to adjust.
