Camburg's 2005+ Prerunner/4WD Performance Spindle Kit - Stock Height
Discussion in 'SDHQ Offroad' started by SDHQ OFFROAD, Jan 10, 2019.
  1. Jan 10, 2019 at 3:40 PM
    SDHQ OFFROAD
    SDHQ OFFROAD [OP] Cuz Stock Sucks! Vendor
    SALES
    Gilbert AZ
    With Camburg's stock length replacement lower arms coming out shortly, it was time for them to release their fully fabricated spindles for the customers wanting the ultimate combination of parts.
    Camburg designed these around the factory OEM spindle geometry and took them to the next level in strength and craftsmanship. With over 15+ years of running history of the stock design and Camburg building custom versions for the military, they took what they've learned and know and applied them to the new Camburg performance spindles. They improved upon the design Toyota started, with a much stronger detailed version. Like their 4.0 spindles, they relocate the ABS speed sensor that is prone to being damaged off-road internally.
    These work on 4wd and 2wd Prerunner models with no modifications regardless if you’re running stock lower arms or a long travel kit. These do not lift the truck or widen it since it’s built around the factory specs. For you 2wd owners, our 4.0 spindles offer lift and an increase in track width. They do remove the provision for the front sway-bar so it will need to be removed. Strength, performance, and articulation was the main focus on a product like this and having 2.5 coilovers with added low-speed compression or a second shock will help to control body roll. They weren’t willing to compromise the integrity of the spindle for the serious off-roaders.
    Using the latest Faro scanning technology and Solidworks CAD/CAM modeling, Camburg builds these in house for the utmost control. They start with steel billets that get heavily CNC machined for weight reduction and precision, MIG weld the laser cut plates, then have them stress relieved, sandblasted and powder coated. Once in your hands, they are ready to be installed and come with all the necessary 12 point Grade 9 hardware.
    FITMENT:
    2005+ Tacoma 2wd
    2005+ Tacoma 4wd
    On our website
    https://sdhqoffroad.com/collections...toyota-tacoma-pre-4wd-performance-spindle-kit
    Motofox likes this.
  2. Jan 15, 2019 at 9:09 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Any word on availability of their stock length lowers that they've posted on their Instagram?
  3. Jan 17, 2019 at 7:50 AM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    Those will go into further testing and production once the spindles are done.
