camburgs with stock rims?
Discussion in 'Wheels & Tires' started by 08pretaco, Jan 4, 2010.
  1. Jan 4, 2010 at 10:15 PM
    08pretaco
    08pretaco [OP] Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    i remember reading but cant for the life of me find it, can you run stock rims (like the ones off the sr5) or even the spare with the camburg spindles?
    total chaos says you need at least 4.5 bs i think but im not sure about the camburgs :confused:
    thanks!
  2. Jan 4, 2010 at 10:46 PM
    waltonhockey17
    waltonhockey17 Well-Known Member
    Alex
    georgia
    08 DC Red Taco
    4" camburg spindles, billys at 0", 16" xd hoss rims, 285/75/16 xtreme mud terrains
  3. Jan 5, 2010 at 12:05 AM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    Almost positive that you will rub with stock wheels unless you throw spacers on there.
    On a side note I'm running 4.75'' backspacing and I don't rub.
  4. Jan 5, 2010 at 8:07 AM
    08pretaco
    az
    Have fun with the install!! Email me if you got questions when doing it :thumbsup:
  5. Feb 9, 2010 at 5:38 PM
    08pretaco
    az
    since they "say" that the wheels to run with this are 4.5" bs and 285's recommended tire size...can i get a 4" backspaced wheel and try to fit some 305/75's under it? like having the wheel offset the wider tire?
    how did the install go alex?
  6. Feb 9, 2010 at 5:42 PM
    1BlkT
    Ty
    90603
    So your going to get a 1/2'' more of space by switching rims but the tire size is slightly more than 1/2'' wider right :confused:?
    I'm guessing it should work though, but I'm not positive either.
  7. Feb 9, 2010 at 6:45 PM
    08pretaco
    az
    Ya but theoritically the difference in width would be halfish and I think 305 are 12" wide 385's are 11.5 and if run those with 5.5 backspacing I think the 305's on 4" should work
  8. Feb 9, 2010 at 7:56 PM
    BIGDEZUL
    BIGDEZUL Well-Known Member
    Baton Rouge
    6" Pro Comp, rockstars, nittos, black mods on interior, debadged, color matched chrome bumper and grille, dynamat inside doors and floor MORE TO COME
    I talked to one of the guys there the other day and he said they should change the website about the BS issue. He told me that 5"-4.5" is acceptable...
  9. Feb 9, 2010 at 8:21 PM
    08pretaco
    az
    With what size tires, 285 and 5" bs? Then also if that happens to be the case then the 305 should fit possibly even with4.5 bs and then maybe 315 (35) with 12.5 might work with 4" bs. Interesting :)
  10. Feb 9, 2010 at 8:47 PM
    BIGDEZUL
    Baton Rouge
    Well I did say 5"-4.5" not 5"-4" of BS so that's not gonna work. Even the 305's would be pushing it. More than likely you would have to cut the cab mounts to avoid rubbing with the 305's...
  11. Feb 10, 2010 at 7:37 AM
    08pretaco
    az
    oh the cab mounts for sure but not a big deal at all, the rubbing on the spindles whats the biggest concern.
    285= 11.22" 305=12.01"
    you said the least amount would be 5" running 285's, so then 4" with 305's should work because the difference in width is less than the backspacing difference. difference of 1" bs is more than .79", which is the difference in wheel width.
    when i get the funds or find a cheap set of 305's i might try them out with my 4.5 bs and see if there is any rubbing on the spindle, then if not trim the inner fender well accordingly.
  12. Mar 21, 2010 at 9:25 AM
    kris219
    kris219 Well-Known Member
    Kris
    miami
    tacoma trd
    spindle lift with dakar leaf pack, blacked out headlights and tailights, satoshi, debadged, HID headlights n fogs, flowmaster 40 single in dual out
    are you guys saying that i cant run stock wheels and tires with camburgs?
  13. Mar 21, 2010 at 9:56 AM
    1BlkT
    Ty
    90603
    I don't know about stock tires but I know with stock TRD 17s and 285 tires you need spacers so the tire doesn't rub the spindle. Maybe with the stock tire you would be okay because it isn't as wide.
