Camelback Toyota Discount for TW Members!!!!
Discussion in 'Camelback Toyota Parts' started by Jorge@CBTParts, Feb 29, 2012.
Thread Status:
Not open for further replies.
  1. Aug 28, 2017 at 9:40 AM
    #2641
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Need two of those. What about the outboard side of the cv? Not a clue what it's called, but most of the metal is rusted off, and the rubber part is pretty worn.
  2. Aug 28, 2017 at 12:09 PM
    #2642
    gunny1005
    gunny1005 Well-Known Member
    Phoenix
    Here is a picture of what you can get separate..
  3. Aug 28, 2017 at 1:17 PM
    #2643
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
  4. Aug 28, 2017 at 2:49 PM
    #2644
    gunny1005
    Phoenix
    Sure can, let me know...
  5. Aug 28, 2017 at 7:40 PM
    #2645
    Mateo74
    Mateo74 Well-Known Member
    Matthew
    NWI
    16' Tacoma Sr5 Blazing blue pearl
    Are these part numbers good for a 03 4x4?
    Kittenmittens4U likes this.
  6. Aug 29, 2017 at 6:38 AM
    #2646
    RipcurlUSC
    RipcurlUSC Well-Known Member
    Jesse
    SoCal
    2006 DCSB 4.0 4X4 Black
    Stuff here and there. Built not Bought. Fabbing w/o Fibbing
    Hey Gary. I'm looking for the seals on the CV axles except for the first one closest to the nuckle. So I'll need...
    Two of these... 90304-A0001
    Two of these... 41336-04010
    90311-47027
    90311-47026
    I guess it doesn't hurt to see what you guys charge for the CV itself 4343004070
    I guess it also helps to have you check and see if I've got the part numbers right.
    Thanks
  7. Aug 29, 2017 at 7:14 AM
    #2647
    gunny1005
    Phoenix
    I have the axle in stock, rest I would have to order
    90304-a0001 $19.07 each
    41336-04010 $5.27 each
    90311-47027 $11.19
    90311-47026 $15.97
    43430-04070 $322.32
  8. Aug 29, 2017 at 9:57 AM
    #2648
    mschein1
    mschein1 Well-Known Member
    Lincoln, NE
    2021 Tundra OR CM
    Need both sides, front lbj's for 2004 Tacoma Double Cab TRD OR
  9. Aug 29, 2017 at 10:50 AM
    #2649
    gunny1005
    Phoenix
  10. Aug 29, 2017 at 3:28 PM
    #2650
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    2006 2TRFE
    -Radiator cap
    -Valve cover gasket set
    -Timing cover Orings for oil pump and water pump(4 orings I believe)
    -Water pump
    -Front main seal
    Plz and thank you!
    TacoTRD78 likes this.
  11. Aug 29, 2017 at 3:36 PM
    #2651
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Hey, I've looked for a complete diagram I could get number add of but can't find one.
    I need every piece of the parking brake cable after the little hinge thing, including the hinge also.
    99 extended cab.
    I don't know what other info you're gonna need...
    Sorry for being a pain.
  12. Aug 29, 2017 at 4:15 PM
    #2652
    gunny1005
    Phoenix
    I would have to order the o-rings
    rad cap 16401-31650 $11.49
    v/c gskt 11213-75041 $13.87
    O-rings 90301-19021 $2.32
    90301-25020 $2.32
    90301-25014 $2.32
    96723-35028 $2.68
    w/pump 16100-79445-83 $84.97
    crank seal 90311-48020 $8.80
  13. Aug 29, 2017 at 4:18 PM
    #2653
    gunny1005
    Phoenix
    There are a lot of pieces back there so I am attaching a picture of the set up to help out..
  14. Aug 29, 2017 at 4:39 PM
    #2654
    RipcurlUSC
    Jesse
    SoCal
  15. Aug 29, 2017 at 4:40 PM
    #2655
    MrCrowntown
    Alyn
    Ky
    Do have the seals for the spark plug tubes as well?
    If you can add that, i'll take it all
  16. Aug 29, 2017 at 4:46 PM
    #2656
    gunny1005
    Phoenix
    that I have to order as well 11214-75010 $9.58
    I will get everything coming
  17. Aug 29, 2017 at 5:51 PM
    #2657
    JKO1998
    Utah
    How a just 46301 and 46441 (x2)
  18. Aug 30, 2017 at 6:26 AM
    #2658
    gunny1005
    Phoenix
    I do have to order these:
    46301-35240 $27.39
    46441-30030 43.25 each
    total shipped $33.89
  19. Aug 30, 2017 at 7:43 AM
    #2659
    JKO1998
    Utah
    43.39 for a nut or 3.25?
  20. Aug 30, 2017 at 7:48 AM
    #2660
    Subway4X4
    Lloyd
    NY/NJ
    :popcorn:
Thread Status:
