Camerond05's build page. Slow. Boring
Discussion in 'Long Travel Suspension' started by Camerond05, Nov 26, 2016.
  1. Nov 26, 2016 at 1:38 PM
    #41
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    The stock axles are pretty strong if u keep the tires small(33's) and yes I built my arms, workin on a beefier kit slowly to make my own spindles and stuff eventually
  2. Nov 26, 2016 at 1:41 PM
    #42
    Camerond05
    Camerond05 [OP] Well-Known Member
    Cameron
    Missouri
    2020 Tacoma DCSB
    Yeah I've got 33s now, was hoping to go to 35s, but if that requires a new axle then I'll have to wait. I noticed you got a new rear axle, 35s for you? Or are you keeping the 33s?
  3. Nov 26, 2016 at 1:46 PM
    #43
    Basikbiker
    Trav
    U can run 35's but if you are gunna be beatin on it, like 50+ through good size whoops and jumps. it'll eventually fail.
    Once I get my new axle in and the 4:88's I'll be switching to 35's, but till then(next month) I'll be runnin these pretty much bald suckers lol
  4. Nov 26, 2016 at 1:48 PM
    #44
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
    Most likely won't be hitting too big of jumps going that fast. What axle did you get?
  5. Nov 26, 2016 at 1:50 PM
    #45
    Basikbiker
    Trav
    I just put a pic in my build thread, full float ford 9 from ruffstuff
  6. Nov 26, 2016 at 1:52 PM
    #46
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
    Yeah man that thing looks badass! What size shocks are you running in the rear? And are you using the shock under axle kit?
  7. Nov 26, 2016 at 1:57 PM
    #47
    Basikbiker
    Trav
    Well I'm runnin an offshoot of a deaver h70 leaf pack, DTF front hangers and rear shackle mounts, my own shackles, and a ruffstuff spring under perch/u bolt kit. Shocks are King 2.5 18" triple bypasses and king 2.0 2" bumpstops works pretty good, I'm happy with it
    Camerond05[OP] likes this.
  8. Nov 26, 2016 at 2:00 PM
    #48
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
    Do you by chance have a pic of that setup? How did you mount the bumpstops?
  9. Nov 26, 2016 at 2:04 PM
    #49
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
  10. Nov 26, 2016 at 2:05 PM
    #50
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    STEP ONE: STOP YELLING
    STEP TWO: DO IT ALREADY
  11. Nov 26, 2016 at 2:06 PM
    #51
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
    IM TRYING! Stupid ass clutch and tranny went out last week.. took all my saved money. :annoyed:
    AR15xAR10[QUOTED] likes this.
  12. Nov 26, 2016 at 2:13 PM
    #52
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
    Should I go 3.5 or 2.0??? Decisions decisions. :confused:
  13. Nov 26, 2016 at 2:14 PM
    #53
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
  14. Nov 26, 2016 at 2:21 PM
    #54
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Check out SDHQ - they have some sales right now. Even when they don't they offer 10% tacomaworld discount plus no sales tax and free shipping. It sounds like you want 3.5 if you're going bed cage. No reason to limit your travel at all after putting money into one. People only stick with 2 if they drive on tight trails or park in a lot of tight spaces like me down here in the city. The kit I bought is +2.5 if I'm going off of the tie rod extensions. Sounds like you're serious about this - exciting!
  15. Nov 26, 2016 at 2:29 PM
    #55
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Tie rod extension isn't an indicator of how wide your kit is. The 2" or 3.5" kits are how much wider the WMS is over stock.
    As an example, the 2" over TC kit uses a 2 3/8" tie rod extension.
  16. Nov 26, 2016 at 2:29 PM
    #56
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
    http://store.sdhqoffroad.com/2005TCtacomalt.aspx
    So it looks like it comes out to around 3100 from them. Better! Going to look at the cost of shocks from them
  17. Nov 26, 2016 at 2:35 PM
    #57
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
    So may be a dumb question.. but. 2.5 diameter up front, but how long? With the 3.5 kit
  18. Nov 26, 2016 at 2:38 PM
    #58
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Start adding costs on top of the kit itself. At a minimum
    Spindle gussets
    Cam tab gussets
    Double sheer coil bucket gussets
    Extended axles
    CV boot kits
    Engine mount perch gussets
    Semi solid engine mounts
    Fiberglass fenders and bedsides
    Front bump stops
    Coilovers
    Frame box kit
    Bed cage
    Spring under leafs
    Spring perches
    Spring hangers
    Shackles
    Shackle hangers
    Rear bypasses
    Rear bump stops
  19. Nov 26, 2016 at 2:38 PM
    #59
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Coilovers are specific to the kit. Generally speaking, 8" travel coilovers with a 16" or 18" spring.
  20. Nov 26, 2016 at 2:42 PM
    #60
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
    So around 10k.. Reasonable. Where are the best places to shop around for these
