Camp Grills, what are you using?
Discussion in 'Outdoors' started by mwaterous, Apr 14, 2019.
  1. Dec 24, 2020 at 7:51 PM
    #81
    rosswood
    rosswood Well-Known Member
    Ross
    South Florida
    2017 SR5 Magnetic Grey
    Current Build: 18” Level 8 Slam Wheels LT285/65/18 Nitto Terra Grappler G2 Icon Stage 1 Lift Kit 2.75” OME HD Dakar Leaf Springs w/extra leaf Caliraised 32” Hidden Dual Row LED LightBar Caliraised Ditch Lights RCI Offroad Short Bed 12” Rack ROAM Adventure Vagabond RTT
    Ive seen quite a few overland youtube pages including Justin Mcbride using the Tembo Tusk.
    https://tembotusk.com/
  2. Jan 6, 2021 at 9:29 PM
    #82
    Taco Pat
    Taco Pat Well-Known Member
    Patrick
    SoCal
    2018 Tacoma TRD Off Road
    I use a regular Coleman 2 burner stove. It’s compact and the 1lb propane bottles are compact and relatively cheap. Can’t be beat in my opinion
  3. Jan 7, 2021 at 12:50 PM
    #83
    Larry de Lobster
    Larry de Lobster Well-Known Member
    Houston
    2021 TRD Off-Road DCSB Super White
    - Front Runner Slimline II Roof Rack - Fox 2.5" DSC w/ R/R, ICON Delta Joint UCA, Deaver Stage II Leaf Springs & Archive Garage U-Bolt Flip w/ 2.7" Super Bumps - CBI Full Overland Skid Plates, Gas Tank Skid Plate & Rock Sliders - Method Bronze 703 17x8.5 w/ 285/70r17 Cooper Discoverer STT Pro
    I recently bought a tembo tusk (guess I jumped on the overlanding bandwagon with that one) since cooking on it for multiple people is relatively easy cause of the size (plus you don't need pans & easy to clean). I also leave it set up on the patio when I don't need it for camping cause it makes meal prepping so much easier than cooking inside. I'll probably end up buying a single or dual burner coleman when I'm only cooking for myself since it'll be easier to set up/take down and I don't have to bring a small burner for my percolator.
  4. Jan 7, 2021 at 10:23 PM
    #84
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    same. except I have one 1lb bottle I refill from a 20lb tank. saves a bunch of money
    cammerv8 and Taco Pat[QUOTED] like this.
  5. Jan 7, 2021 at 10:42 PM
    #85
    Taco Pat
    Patrick
    SoCal
    I hadn’t thought of that. Great idea, I’ll have to look into it
  6. Jan 8, 2021 at 10:54 AM
    #86
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    I have mixed feeling for my tembo tusk.... Its fun to cool on, the heat in the center is pretty small... Too hot it burns the center real quick. its annoying to tear down when you're on the go... Burns propane due to cooking/cleaning it off.... ( I get free refilled on propane)
  7. Jan 8, 2021 at 11:12 AM
    #87
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    I bought one of these a few months ago and have been very happy with it. The Timbo Tusks are cool but I can't justify the price. This has been a huge upgrade from the Oazark Trails two burner I was previously using. Makes camp cooking actually enjoyable! :hungry:
    It is a little heavier than I'd prefer and slightly larger than I need but it makes cooking for the group easier.
    https://www.amazon.com/Blackstone-Table-Top-Grill-Tailgating/dp/B0195MZHBK
    cammerv8, jackn7, Lord Helmet and 5 others like this.
  8. Jan 8, 2021 at 11:16 AM
    #88
    BalutTaco
    how heavy are these?
  9. Jan 8, 2021 at 12:03 PM
    #89
    desertjunkie760
    Shane
    Check My Sig.
    21 LBS is what they have listed on their website. 95% of the weight is the cooking surface itself.
  10. Jan 23, 2021 at 3:46 PM
    #90
    DarinL
    DarinL Well-Known Member
    Darin
    2017 Tacoma 4x4 TRD 4-dr longbox
    I go light and small for as much stuff as possible and lots of the places my family of 4 goes involves hiking and getting away from the truck or campsite. For that reason, we use lots of backpacking type gear instead of trying to create a household or RV kitchen in a truck. With that philosophy in mind (and I understand it's not for everyone), the MSR Dragonfly is a great lightweight stove. It weighs ~400grams which is under 1 pound. Runs on white gas (and other liquid fuels with nozzle swap outs) without any soot. It has 8700BTU of maximum output but the beauty of it is the ability to simmer and cook at any heat output. I threw away the crappy foil heat shield and instead use a Fire-Maple folding windscreen that needed some minor adjustments to fit over the gas line but it adjusts to fit small pots to big pots. This means that it can be used for camp and also for hiking day trips and other backcountry usage. If instead, you want to always be within meal distance from your truck and want to cook multi-pot meals for lots of people then some format of Partner Steel stove is the best there is. I wish they would come up with a dual-stage burner for better control on low temp cooking but that's a minor nitpick for something that is built to withstand a nuclear blast.
  11. Jan 24, 2021 at 9:04 PM
    #91
    4wdmurph
    4wdmurph Active Member
    LA
    2016 Tacoma TRD Off Road
    Seems like a good enough size for me :thumbsup:
  12. Feb 3, 2021 at 5:30 PM
    #92
    Jbart22
    Jbart22 Well-Known Member
    Jess
    Ogden, UT
    17 OR DCSB Inferno
    I recently got the stansport outfitter series 2 burner. Man this thing puts out some HEAT! 25000 BTUs per burner, that's way more than pretty much every other similar style stove. It made Thanksgiving dinner for 5 at Big Bend NP last year.
  13. Feb 25, 2021 at 2:23 PM
    #93
    Rhann86
    Rhann86 Well-Known Member
    2017 TRD Off Road Crew Cab Long Bed
    Classic green Coleman 2-burner with a separate griddle top.
  14. Mar 21, 2021 at 10:38 AM
    #94
    cloudpunch
    cloudpunch Member
    Southern California
    2014 ACLB, 6 Speed Manual, 4WD TRD OR, Tow Package
    Anyone have any suggestions on good way to modify the windscreen supports on a Cook Partner stove? Those squiggly wires are prone to catching on things (like jackets & sleeves) and a decent breeze will blow the windscreen right off them. I want to swap them out for something more like the bent wire Coleman uses but am not sure what the best way to mount them would be.
    Screen Shot 2021-03-21 at 10.31.31 AM.jpg Screen Shot 2021-03-21 at 10.36.50 AM.jpg
  15. Apr 4, 2021 at 7:00 PM
    #95
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    jackn7 likes this.
  16. Apr 5, 2021 at 4:57 PM
    #96
    slidemx5
    slidemx5 Well-Known Member
    Rob
    21 DCSB OR Manual!
    On my first real outing with my little single burner butane Coleman, i noticed a real degradation in heat due to a cold temperature.
    Does this happen less with propane or other fuels?
    Thanks!
  17. Apr 6, 2021 at 12:15 AM
    #97
    RedWings44
    Michigan
    I'm not familiar with using butane, but propane has been great. Most recently I was able to cook breakfast below freezing with 20mph wind. Proximity to the flame and blocking the wind are key.
    The down side is that the faster you use propane, the more it tends to freeze. This problem gets worse as the temperature gets colder and the bottle gets emptier. In my above example, I had to replace the bottle about half way through cooking each morning due to this issue. But I also had both parts of the grill /stove going and was only using a small green propane bottle. Meanwhile I was cooking breakfast for 4 people.
  18. Apr 6, 2021 at 5:13 AM
    #98
    huachuca
    huachuca Well-Known Member
    Al
    Tarboro, NC
    2012 4WD DC w/TRD offroad
    Butane stops vaporizing at around 31*F and performance suffers even before it gets that low so not the best choice for cold weather cooking. Propane is better but the old tried and true Coleman liquid fuel (Naptha) is an improvement on that. I have a https://www.coleman.com/camp-kitche...s-compact-dual-fuel-stove/SAP_3000003654.html that is a great little single burner which stores compactly in a large coffee can. These can often be found at yard sales for $10-20. Mine is from the early nineties but is the newest stove in my kit - my primary is a 413E double burner from 1962.
  19. Apr 20, 2021 at 7:51 PM
    #99
    alexcruz
    alexcruz Member
    alex
    Truckee, California
    2012 Blue Tacoma TRD
    Has anyone used a HitchFire grill? Been looking at these as I wanted a bigger grill and won't take up space in the rig, but trying to decide if the hitchmount is the way to go. Some youtube videos I've seen look like they hold up, but maybe others have tested?
    Hitchfire.com
    PiryongS likes this.
  20. Jun 7, 2021 at 3:30 PM
    #100
    smartbomb
    smartbomb rcvr/xmtr
    usually northwest of you
    2006 4-door prerunner long bed
    3" suspension lift, hard canopy, light bar in hood, ditch lights, aircraft cargo bars, powdercoated steel spares, desert tires, bed cargo bars (for rifle cases), misc interior doo-dads
    It's summer now and I've moved to a Snowpeak Takibi folding fire pit
    which kicks all sorts of ass. I love it.
    .劉煒 likes this.
