Camp Lighting?
Discussion in 'Lighting' started by AM_Taco, Jul 12, 2022.
  1. Jul 13, 2022 at 11:50 AM
    AM_Taco
    AM_Taco [OP] Well-Known Member
    2020 Tacoma TRD Off-Road
    Yea they definitely dont look out of place, I like the quality of BD so definitely a setup to consider.
  2. Jul 13, 2022 at 12:35 PM
    Bholm
    Bholm Well-Known Member
    B
    2017 Silver Tacoma SR5
    funny. I was just thinking about buying a set of rock lights and doing the 4 in the wheel wells and the set i found has six and was going to attach the other two to my rack
  3. Jul 13, 2022 at 12:38 PM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    What are you a teacher? You got eyes in the back of your head?
    AM_Taco[QUOTED][OP] likes this.
  4. Jul 13, 2022 at 12:52 PM
    clock11
    clock11 Well-Known Member
    Aaron
    Southern California
    2020 White TRD Off Road
    Deaver Stage III, Icon Stage 3 (minus Icon leafs), BFG K02s, Prinsu roof rack, Diamondback HD, CaliRaised Ditch lights and Brackets, Clazzio Seat Covers, Rearseat 12v Power & USB, Bed cubby 12v Power & USB, Interior LED bulbs, Toyota OEM tailgate lock.
  5. Jul 13, 2022 at 4:44 PM
    AM_Taco
    Hahaha. I meant something that would light up an area as opposed to lighting up just where im looking lol. But maybe youre on to something, I'll just wear 4 headlamps so Ill have 360 degrees of light.
    AxisCab likes this.
  6. Jul 13, 2022 at 7:36 PM
    Taco 422
    USA
    Do it in a Bigfoot onesie and you'll be on to something.
  7. Jul 13, 2022 at 8:02 PM
    AM_Taco
    Id imagine the bigfoot fanatics would have a field day with that one
  8. Jul 14, 2022 at 6:38 AM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    I would go for something like that Devos light, Milwaukee telescoping light or something that telescopes and covers a wide area. Truck mounted lights are useful, but if you have your back to the truck you'll have shadow and if you are facing the truck (like sitting in a chair) you'll be looking right at the lights if looking in that direction.
    As far as headlamps go, I LOVE my Milwaukee 2111 rechargeable headlamp. I've been using it for about 5 years. It has a real world 8-9hr run time on Med Flood, even after 5yrs of use. I mainly use it for working on cars. The nice thing is the light color temperature. Colors are accurate and it's not 6000K like most LED headlamps so it doesn't blow out your night vision when you turn it off. The only downside is that it is made for hard hats and can be a little uncofratable. The 2115 would be better for comfort and has similar run times, my buddy has had that one for a couple years but I haven't gotten it since my 2111 hasn't failed yet. Don't believe the reviews on Milwaukee's site, I know many people with both of them and none of us has ever had an issue.
  9. Jul 14, 2022 at 9:20 AM
    AM_Taco
    Yea thats true, which is why I was also considering some string light type system. I'll definitely look into the Milwaukee though.
    TacoFergie[QUOTED] likes this.
  10. Jul 14, 2022 at 9:37 AM
    TacoFergie
    Iowa
    String lights and LED strips would work ok. Only issue is that you often won't have much usable output. Most only provide low ambient lighting which is fine for sitting around and BS'ing but not so much for actually doing anything that requires detailed work like food prep or playing games. It also depends on if you want the lighting to be powered from the truck or from it's own power source. Personally, I prefer to keep it separate from the trucks power incase you forget to turn it off and drain the battery or you have a battery that's close to end of life and find out the truck won't start after a couple hours of running your lights. But that's just me. I like to have back-ups for the back-up. haha
  11. Jul 14, 2022 at 9:39 AM
    Bholm
    B
    i use LED strips in the bed of my truck. Very similar to the gecko or matt gecko lighting option and have mine hooked into a Anker power block that i leave back there just for those lights. Perfect for ambient lighting and bright enough so i can actually see what im doing and looking for back there
  12. Jul 14, 2022 at 10:19 AM
    TacoFergie
    Iowa
    That's a great idea using a power bank!
    The issue I see using an LED strip as an area light/string light is that LED strips without a diffuser or something to direct the light it won't project light very well when they are 7+ feet from the ground. That's why most camp or work lights have either a diffused lens or a reflector of some sort to direct the light. I tried a water proof strip under the awning covering my back patio where I grill and found that it wasn't much light at all for actually seeing what I was doing. It was enough for ambient light though.
  13. Jul 14, 2022 at 11:04 AM
    AM_Taco
    I have a similar setup but I’m wired to my main battery with a switch. I figure that’s enough lighting to do anything in the bed of my truck, all I need now is something for lighting up camp
    TacoFergie likes this.
  14. Jul 15, 2022 at 2:49 PM
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    I usually bring an assortment and it is always more than I need. Like a few others, I try to keep light low at night to not be "that family" in the campground, although there is usually around some other jackass doing it while being loud and obnoxious anyway.
    Here is my mix depending on # of people. Solo I only bring a few options, none of these are crazy, max 200 lumens. Move them around as needed.
    1. A few Fenix flashlights with diffusers for the ends
    2. A small, basic Nite-Ize portable light that just takes 3 AAA batteries. This is my primary light for inside tent or shell if I am solo (that is where I sleep solo)
    3. A larger Nite-Ize that takes 3 D batteries. This is my primary outdoor light.
    4. A basic headlamp with hi and low
    That is pretty much it. I would like a get a few basic LED light strips for some mood lighting.
    AM_Taco[OP] likes this.
