Camper electrical question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boatbuilder, Feb 8, 2015.
  1. Feb 8, 2015 at 2:37 PM
    boatbuilder
    boatbuilder [OP] Well-Known Member
    Jim
    Tonasket, WA
    12 regular cab 4 cyl 4wd
    A lot!
    Looking for a flush mount receptacle to mount on the side in the bed to plug a camper into. NO, I don't want or need a 4way, 7way, etc. camper plug. All I need is a line to charge the battery in the camper off of a dual battery isolator. The rub is the bigger wire size the better for less loss in resistance. I would like to use a fork lift plug but can't find a flush mount. So, ideas and no I don;t want to use a house outlet either. There has to be a heavy duty 2 prong plug like the cheapies you buy at Radio Shack???
  2. Feb 8, 2015 at 4:05 PM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    Maybe radioshack. Better hurry up before they go out of business. (Which was sad to hear)
  3. Mar 3, 2015 at 12:18 PM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Jim, maybe the tracker trailer dealer will have what you are looking for. Voltage loss can cause undercharging of you house battery resulting in a premature battery failure from a gradual buildup of lead sulfate. Periodical "topping off" your house battery with an external charger can solve this problem.
  4. Mar 3, 2015 at 12:22 PM
    boatbuilder
    Jim
    Tonasket, WA
    A lot!
    What? All I was looking for was the plug. I have the charging all in order. I ended up with a flush mount Sierra Trolling Motor Plug with spring loaded flap. Nice plug for anyone doing the same
