Camper setup question...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jaguar Shark, Jul 3, 2016.
  1. Jul 21, 2016 at 5:53 PM
    WtsTacoma01
    WtsTacoma01 Member
    Bill
    Raleigh, NC and Norfolk, VA
    2001 SR5 DC 3.4L V6 4x4 Auto "Lunar Mist"
    ARB Rear Air Locker (4.10 gearing), ARB Air Compressor, Rear Air Firestone "Ride-Rite" System with matching compressor and inside mounted air pressure gauge, Bilsteins 5100 Shocks front and rear (1" Over), OME 883 Coilover Springs Front and Deaver Rear 9 Leaf Springs for 3" Lift, ARB Bull Front Bumper with Warn Winch 9.5 XP-S, Warn Remote Control Truck Module and Factor55 thimble, Mounted Hi-Lift 48" X-Treme Jack, ARB Safari Snorkel, Kenwood DNX891 with Navigation, Sirus, Focal 6 1/4 Front Speakers, Focal 5x7 Rear Speakers, Focal Digital 400 Amp,Gentex GENK20A Temp / Compass Sensor Rear View Mirror, Kenwood CMOS-320 Front and Rear Backup Cameras, CB Cobra 75 WX with Firefly Antenna, Rigid 20" 12161 E2 Series LED Driving Light Bar, ARB Intensity LED Driving Spots AR32S, Optima "Yellow Top" D34/78 Battery, NationsAlternator 180hp (Hair Pin) 180 Amps Alternator, 2001 Tundra 199 mm S13WE Front Calipers and Hawk Super Duty Pad Brakes with Powerslot Cyro Slotted Rotors sized for 2001 Tundra, Front and Rear Braided Stainless Brake Lines, Mobile 1 0w-30w Synthetic Engine Oil with Oversize Toyota Oil Filter (Part Number: 90915-YZZD3), Lucas Synthetic Transmission and Differential Oil, ARB 170112 Differential Breather Kit (Front and Rear Differentials, Transmission and Transfer Case) WheelSkin Steering Wheel Wrap, ProComp XTreme MT2 265/75R16 mounted to ProComp LA PAZ Series 29 Rims, 15.5 Gallon Auxiliary Transfer Fuel Tank with Inside Transfer Switch from NWMP (Sunset Fabricators) with Drake Off Road Locking Fuel Caps, Heated Front Seats, Relentless Tacoma Wrap Around Rear Plate Rear Bumper with Rigid Industries 51251 D2 60 degree diffused Lens LED Lightflush Mount for Rear Bumper with Built-in Trailer Hitch. Delta Pro Aluminum Decking Toolbox, Carry: ARB High Air Compressor with Tank (ARB CKMTP12) in Pelican Box, ARB Orange Speedy Tire Plug Kit, ARB Large Recovery Bag with Winch Extension, Tree, and Snatch Straps, ARB Snatch Block and Clevis D Rings, Hi-Lift ORK Off-Road Kit.
    That is Awesome "Jaguar Shark". Glad that works for you. Happy Trails!
  2. Jul 25, 2016 at 7:54 AM
    Voyager
    Voyager Well-Known Member
    Bob
    Virginia
    04 Tacoma DC 4X4 TRD V6
    OME Suspension kit Magnaflow SS catback, ARE cap, Yakima kayak & bike racks, Deck Lid, Westin Safari Light Bar.
    Jaguar Shark
    You should be happy with the setup. Enjoy!
    Yes – instructions said bolt top and bottom. The kit was fitted with components appropriate to the amount of axle/leaf spring articulation found on our stock truck. Once you change a parameter, such as swap to a different leaf pack, you just changed the operating conditions.
    If you are staying with OEM leaf pack, you shouldn’t have any issues.
    If you go to new leaf pack that requires an extended brake line, it would be reasonable to assume it may also possibly require “extended” bags…
    I just added Dakars last weekend. Will reinstall the bags shorty and will experiment.
