Camper shell AAL question
Discussion in 'Tonneau Covers, Caps and Shells' started by rwcfrank, Mar 14, 2010.
  1. Mar 14, 2010 at 10:05 AM
    rwcfrank
    rwcfrank [OP] Well-Known Member
    08 SR5 Prerunner
    I installed a camper shell on my 08 Pre-runner with the TSB done. The truck sits ass down now and bottoms lightly when fully loaded. I want to add a leaf that both lifts slightly and adds some carrying capacity. Anyone have a suggestion for a reasonble fix? I wanted to go with bags because I do haul heavy loads on ocassion but they are a bit pricey. thanks in advance for your time and opinions.
  2. Mar 14, 2010 at 11:16 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    Bilstein 5100 CO's @ 1.75" - Icon UCA's - TSB Rear w/Bilstein 5100's - Air Lift System - Flowmaster 50 Duals(RIP...back to stock for now) - Avid Offroad Arctic Bar - Avid Offroad Nerf Bars - Leer 550 Bedcover - AVS Hood Protector(RIP) - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    Cheap fix would probably be an AAL from Toytech. Seems weird your butt would sag with the TSB done even with a cap.
  3. Mar 14, 2010 at 11:21 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    x2 I'd check and make sure they put the TSB 4 leaf packs on. I think there have been a few cases where the dealers just put a new set of non-TSB 3 leaf pack on the truck.
  4. Mar 14, 2010 at 11:49 AM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    In my case they didn't put anything on the first time. Had to go back and tell what's up, then get the real 4 leaf TSB kit.
  5. Mar 14, 2010 at 11:51 AM
    rwcfrank
    08 SR5 Prerunner
    Thanks guys, I did get the 4 leaf packs after they tried to install a 3 and a 4 leaf pack. It sits about dead level with a 1.5 spacer lift in the front and the TSB in the rear. Once I start to load it drops low in the rear. I may try bags after all. Nothing else seems to work as well IMHO.
