Camper Shell/Bed Liner Combo and Securing Shell Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by groink, Apr 20, 2011.
  1. Apr 20, 2011 at 5:43 PM
    groink
    groink [OP] Member
    James
    Laramie, WY
    96 LX 4cyl 4x4 XCAB
    Hello all,
    My taco has the stock removable plastic bed-liner. I recently purchased a camper shell and decided to just leave the bed liner on. Obviously the lip of the liner hangs out a small amount between the bed and the shell. Besides aesthetics, is there any other reason that I should potentially be worried about this set up?
    Reasons I decided to keep bedliner:
    Standard bed liner protection.
    I also figured that the additional space between the actual bed and myself may add additional insulation when using the camper shell for its intended purpose. This is probably pointless as I will use a twin innerspring mattress when sleeping in it.
    Another question:
    I installed the shell using standard 'j-hooks', they just do not seem like they are going to stand the test of time especially with any off-roading... I have not been off-roading since installing the shell, should I be concerned if I make sure they are tight before I go out?
    Thanks!
  2. Apr 20, 2011 at 7:24 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Should be able to run the bedliner no problem.
    As for the J hooks, I look at replacing them with some clamps used for camper shells. They have a larger surface area that holds the shell to the truck.
  3. Apr 20, 2011 at 7:45 PM
    groink
    groink [OP] Member
    James
    Laramie, WY
    96 LX 4cyl 4x4 XCAB
    okay cool, I imagine claps will require cutting into the bed liner? That's not an issue, just curious.
  4. Apr 21, 2011 at 12:37 PM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    I have a factory bedliner along with a Leer camper shell. No issues.
