CAMPER SHELL INTERIOR MOUNTS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TicoTRD, Jun 13, 2018.
  1. Jun 13, 2018 at 7:37 AM
    TicoTRD
    TicoTRD [OP] Well-Known Member
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    Sup fellas, just got a camper top and wanted to mount a couple things to the interior. im thinking a flashlight, fire extinguisher, pvc pipe (fishing rod holder) and maybe a couple other things. my problem is idk how to achieve this. screws would obviously be the most sturdy, but im unsure of where i can screw into the camper shell or if i cant even screw into it at all. anybody come up with cool ideas of how to mount things? or anybody have any advice on how to do so? thanks in advance!
  2. Jun 13, 2018 at 7:42 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Some people have retrofitted a net to the top of the cap if that is what you want to do. There are number of other options that you can use to mount those things to the side of your bed on the interior. @CaliRaisedLed makes a side mounted Molle panel for the bedside interior. Then all you have to do is pick up some MOLLE pouches for the flashlight or some straps for the PVC pipe or fire extinguisher. Here is the TW link
    https://www.tacomaworld.com/threads/05-18-tacoma-bed-molle-system-caliraisedled.539725/
  3. Jun 13, 2018 at 7:51 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    yea i am already going to get the net for the ceiling. i was planning on getting a flashlight mount to install in the back corner of the shell, which would require me to drill into the shell itself (pretty sure not possible since the shell isnt all that thick). and i building a sleeping platform that would take away from the molle system so idk how im gonna make this work.
  4. Jun 13, 2018 at 7:53 AM
    crashngiggles
    Jared
    What type of shell it? Anything is possible. You might be able to get a couple of bolts through after you drill a hole through the shell and put some rubber grommets on the top side of the bolt coming out of the roof the shell to maintain water integrity.
  5. Jun 13, 2018 at 7:59 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    I have an ARE. i hate to be a debbie downer but id like to avoid drilling through the shell.
    Tactical_Panda likes this.
  6. Jun 13, 2018 at 8:18 AM
    crashngiggles
    Jared
    I agree....that is why you might want to try the interior side of the bed option.
  7. Jun 13, 2018 at 8:20 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    I feel ya. thats prob what im going to end up doing.
  8. Jun 14, 2018 at 5:00 AM
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    Fiberglass or Metal?
  9. Jun 14, 2018 at 5:19 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    fiberglass
  10. Jun 14, 2018 at 5:24 AM
    Tactical_Panda
    Tim
    Fredericksburg, VA
    OK. Are you any good with working with fiberglass? If it were me, here's what I would do.
    Remove the shell from the truck and flip it over. Use some Liquid Nails or something similar and glue down some 1-inch thick boards to the inside of the roof.
    Once the glue has set up, get some fiberglass cloth and resin, and glass over the boards and the surrounding roof area. Paint to suit.
    Now you can (carefully) drill into the 1-inch boards and use them as attachment points.
    seedy_tea likes this.
  11. Jun 14, 2018 at 5:26 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    sounds like a great idea but im not good w/ fiberglass since ive never dealt with it and the inner lining of my shell is carpet.
  12. Jun 14, 2018 at 5:27 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    yea i might end up doing that. i was just trying to have it on the shell so it would be out the way of my sleeping platform.
  13. Jun 14, 2018 at 5:29 AM
    Yukon
    Yukon Well-Known Member
    2009 Magnetic Grey SR5
    I put a roof rack on my camper shell and use some of the bolts going through as anchor points for bungees to hold rods up there. Easiest thing for extinguisher and whatnot is some quick fists in the railing. I've also seen people make rod holders out of wood that go between the ceiling and railing where the windows are. I would guess some sort of threaded pressure system is used to keep it in place.
    R11B likes this.
  14. Jun 14, 2018 at 5:36 AM
    Tactical_Panda
    Tim
    Fredericksburg, VA
    Well, it was a thought. :)
  15. Jun 14, 2018 at 5:38 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    appreciate it tho bro.
  16. Jun 14, 2018 at 5:38 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    yea thats what im going to do with my net
    Yukon[QUOTED] likes this.
  17. Jun 14, 2018 at 5:39 AM
    Tactical_Panda
    Tim
    Fredericksburg, VA
    Do you have rails on to of the shell, like to mount a roof rack? If so you could put in longer bolts and use them as attachment points.
    Yukon likes this.
  18. Jun 14, 2018 at 5:42 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    yes i do. thats what im going to do to install my storage net.
    Yukon likes this.
  19. Jun 14, 2018 at 5:44 AM
    Tactical_Panda
    Tim
    Fredericksburg, VA
    seedy_tea and Yukon like this.
  20. Jun 14, 2018 at 6:35 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
