Camper shell not sealing
Discussion in 'Tonneau Covers, Caps and Shells' started by lordetaco, Dec 4, 2016.
  1. Dec 4, 2016 at 1:56 PM
    lordetaco
    lordetaco [OP] Well-Known Member
    Tristan
    Lawton,OK
    2005 Toyota Tacoma
    We just moved out in the country and I noticed I'm getting a lot of dirt in there. I don't mind washing it and it doesnt brother me that much cause all I have back there is trash most the time but I want to put a Truck Vault in there or something similar so I was wondering if it has happened to anyone else and how they fixed or if you can't.
  2. Dec 4, 2016 at 1:58 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Where is it coming in? Around the tailgate, or from the sides, or where, if you can tell?
  3. Dec 4, 2016 at 2:00 PM
    lordetaco
    Tristan
    Lawton,OK
    2005 Toyota Tacoma
    I can't really tell honestly I checked all my windows so it has to be. Maybe has nothing to do with camper shell might be the tailgate.
  4. Dec 4, 2016 at 8:13 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Have someone get underneath your truck with a bright light while you climb in the back and look for light leaks. Not sure which year your truck is but they leak dust around the cubbies/storage compartments, between the pieces of the composite bed and the biggy- around the tailgate. Also check to make sure that your rear window seals, especially in the corners near between the tailgate, shell and shell's rear window. I pulled my cubbies and put thin weatherstripping around them, taped the seams in the bed and added a tailgate seal. It helps a lot but it still leaks some.
  5. Dec 4, 2016 at 8:20 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    It will come in at the bottom of the tailgate between the tailgate and bed floor. It will also come on along the sides of the tailgate where the latches are.
  6. Dec 4, 2016 at 8:25 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Spray around it with a hose hit the Windows and seams with light-medium pressure
