Camper shell on 2013 AC TRD will extra weight require rear suspension mod.
Discussion in 'Suspension' started by P33Rob, Apr 14, 2014.
  1. Apr 14, 2014 at 6:14 PM
    P33Rob
    P33Rob [OP] Well-Known Member
    Rob
    Watertown, NY
    13 Tacoma V6 TRD 4X4
    OME 3" Lift; Maxfit aeromax; Volant CAI w/scoop; TRD Exhaust; Step rails; SCS stealth 6 wheels; Bedrug
    Like the title says adding a camper shell that weighs roughly 250 lbs and my vehicle is a 2013 access cab TRD sport. I am wondering if the cap is going to cause the rear to sag. I was wondering if it is worth doing an add a leaf. If the added weight is going to affect the rear suspension if its on there all the time also, I will have a heavy rubber floor mat (40 lbs) in the vehicle and a 100 lb dog a majority of the time.
    Any comments from experience would be greatly appreciated.
  2. Apr 15, 2014 at 4:41 AM
    P33Rob
    Rob
    Watertown, NY
    Does anyone have any experience in This?
  3. Apr 15, 2014 at 4:59 AM
    SSG665
    SSG665 Well-Known Member
    Georgia
    18 Tacoma
    It may squat an inch or so.You could take measurements as it sits today and then re-measure after adding top,dog,mat,and full tank of fuel.1.5'' add a leaf would probably work well.
  4. Apr 15, 2014 at 5:00 AM
    SSG665
    Georgia
    18 Tacoma
    My 03 squats a good bit with my top but I also have a 12 yr. old leaf pack.
  5. Apr 15, 2014 at 5:17 AM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    I carry 300lbs of tools in the back of my 13.. yes, it does squat some. But what is more bothersome is if you crawl under it the leaf springs look flat (horizontal). I put a 2.5 Deaver AAL on it and raised the front with OME springs. Problem solved.
  6. Apr 15, 2014 at 5:47 PM
    P33Rob
    Rob
    Watertown, NY
    Thanks for the info I guess I will have to see once its on.
  7. Apr 16, 2014 at 8:18 AM
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    I have a '13 TRD OR AC, put a snugtop rebel on it last fall and it dropped the rear about 1 inch. There is still some rake. The only time it "bro'd up" was when I loaded the bed with a shit ton of ceramic tile, bags of thinset, grout and cement board.
  8. Apr 16, 2014 at 8:28 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Wheelers HD leaf pack
  9. Apr 30, 2014 at 7:20 PM
    P33Rob
    Rob
    Watertown, NY
  10. May 1, 2014 at 5:16 PM
    P33Rob
    Rob
    Watertown, NY
    No comments? Only drop about a half inch
  11. May 1, 2014 at 5:17 PM
    OZ-T
    Peter North
    British Columbia
    LocoLocal likes this.
  12. May 2, 2014 at 6:09 AM
    P33Rob
    Rob
    Watertown, NY
    I'm on the trd suspension if if makes much difference I assume its a little stiffer
