Camper shell rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Matu4x4, Oct 28, 2020.
  1. Oct 28, 2020 at 2:07 PM
    Matu4x4
    Matu4x4 [OP] Member
    Hi I need help
    I’m trying to instal a roof top tent in top of my camper shell but the shell only can hold 175 pounds.
    I need something like the picture
    Can anyone help me
    Thanks
  2. Oct 28, 2020 at 2:08 PM
    CO_0321er
    CO_0321er Well-Known Member
    what shell do you have
  3. Oct 28, 2020 at 2:09 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    That definitely looks like a custom one-off that requires hacking up your topper, you sure you wanna do that?
    Having the tent that high up kills MPG and can make your rig awfully tippy too...
    Naveronski likes this.
  4. Oct 28, 2020 at 2:12 PM
    Matu4x4
    Matu4x4 [OP] Member
    I have one snug top
  5. Oct 28, 2020 at 2:13 PM
    CO_0321er
    yeah. bye bye warranty if you cut it up like that. Most toppers have 2 different weight ratings. Dynamic and static. your rating at 175lbs might just be the dynamic weight rating... meaning the rating of what the topper can hold while you do donuts in the mall and hit jumps on trails.
    The weight rating for static... meaning the rating of what the topper can hold while you sleep all cuddled up and cozy... is much much higher than 175.
    But I can't say what your toppers actual ratings are. that's just how most are rated.
  6. Oct 28, 2020 at 2:15 PM
    Matu4x4
    Matu4x4 [OP] Member
    Key-Rei what do you recommend me to do
  7. Oct 28, 2020 at 2:16 PM
    CO_0321er
    find out exactly what your rating is.... is it 175 dynamic? if so, is your tent under 175 lbs? if so you're good if not, then you'll have to modify something
  8. Oct 28, 2020 at 2:19 PM
    Key-Rei
    Key
    Florida
    If you really feel the need to carry a RTT get a low rise cross bar system that allows to mount the tent about even with the roofline of the truck, lowers the CG considerably and doesn't hit MPG as bad, however from the looks of it, the rear bumper the big tires the lift cut fenders, like me miles per gallon doesn't matter so much anymore. :rofl:
    As for gear, get some water tight boxes and id you need extra security a roll-n-lock "garage door" tonneau cover.
  9. Oct 28, 2020 at 2:22 PM
    Key-Rei
    Key
    Florida
    As someone who deals with structural FRC (fiber reinforced composites like truck toppers are) on a daily basis, you could also go to a fab shop and have them make internal aluminum ribs to support and transfer the load to the bed rails from the inside, done right they could be removable and not require cutting the topper.
  10. Oct 28, 2020 at 2:25 PM
    Matu4x4
    Matu4x4 [OP] Member
    I just called snug top and the told me that the shell can hold 175 static
  11. Oct 28, 2020 at 2:30 PM
    Key-Rei
    Key
    Florida
    So as long as your RTT weight doesn't exceed that when it has bedding and is wet you're fine to mount it, another consideration is getting load bars like Yakima or the like that will transfer the weight from the middle of the fiberglass where it's weakest and must bear the load across the fibers to closer to the vertical edges edges where it can support the load more strongly.
    Hard ro explain been up for 24 hours but I think you get it.
  12. Oct 28, 2020 at 2:31 PM
    8Whiskey2
    8Whiskey2 Stellaaa
    Travis
    Arkansas
    2019 Cavalry Blue TRD Off Road
    Derp, LEDs, BFGs, Leer Camper
    That doesn't sound right. Leer told me static weight capacity is 600 lbs on all their caps.
  13. Oct 28, 2020 at 2:34 PM
    Key-Rei
    Key
    Florida
    Depends of the series I suppose, all their X series may be but all their Y series can't. Different thickness different resins, different glass chop strand, woven, layed up or sprayed up etc.
  14. Oct 28, 2020 at 2:38 PM
    8Whiskey2
    8Whiskey2 Stellaaa
    Travis
    Arkansas
    Maybe, but...
    cwadej likes this.
  15. Oct 28, 2020 at 2:39 PM
    Key-Rei
    Key
    Florida
    Fair enough, but OP said his is a snuggtop.
  16. Oct 28, 2020 at 2:41 PM
    8Whiskey2
    8Whiskey2 Stellaaa
    Travis
    Arkansas
    Fair enough, but all I said is that 175 lbs didn't seem right.
    I never said "well, Leer can hold this, so your Snugtop should be fine."
  17. Oct 28, 2020 at 2:44 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    I would suggest a quality rack like
    Prinsu, front runner, or victory 4x4
    And the GFC superlite RTT
    it weighs 80lb
  18. Oct 28, 2020 at 2:55 PM
    beorn the fat
    beorn the fat Well-Known Member
    How much do most ya’lls RTTs weigh?
  19. Oct 28, 2020 at 3:12 PM
    Matu4x4
    Matu4x4 [OP] Member
    My RTT weigh is 150lbd
