CAmper shell sizing
Discussion in '1st Gen. Tacomas (1995-2004)' started by paulbunyan, Aug 15, 2010.
  1. Aug 15, 2010 at 10:03 AM
    paulbunyan
    paulbunyan [OP] Well-Known Member
    I have found a camper shell on craigslist that fits a 1994 single cab toyota pickup with a standard 6ft bed. I have a 1999 single cab tacoma with a standard 6 ft bed. Do you think the 94 shell will fit the 99.
  2. Aug 15, 2010 at 10:07 AM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    debadged, rear spring TSB, leveled with Bilstein 5100s at 1.75", Goodyear Duratrac 265/75/r16, Leer shell with Yakima rack
    I think they're the same bed size, but ask if you can go and test fit it.
  3. Aug 15, 2010 at 10:07 AM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    BTW, welcome to TW.
  4. Aug 15, 2010 at 10:10 AM
    paulbunyan
    I beleive they are the same bed size but I am wondering if the front of the camper shell will fit right up against the cab. thanks for the welcome
  5. Aug 15, 2010 at 4:45 PM
    spp
    spp OC, Kalifornia
    OC California
    Go to the website of a shell company and see if the shell that fits the old PU is the same as the 1st gen Tacoma. I say no. the cabs have different profiles even if the bed dimensions are the same.
  6. Aug 15, 2010 at 7:43 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Yes, it will fit the bed and should fit against the cab.
    I have a snugtop from a toyota pickup and it fits pretty close to perfect on my 01 Xtra cab.
  7. Jul 8, 2015 at 12:25 PM
    professorman
    professorman New Member
    1999 Black Tacoma SR5 4cyl 5spd Extended cab
    What is the bed dimensions of the 99 Tacoma Xtra cab 2wd? I can't find it from a simple search.
    I am trying to find the dimensions so that I can know what to ask of the camper shells that I see on craigslist. I do not know which dimensions shell will fit my Tacoma.
