Camper shell wiring step-by-step (Picture Load warning!!)
Discussion in 'Technical Chat' started by majorhavok, May 27, 2013.
  1. Jul 5, 2019 at 10:49 PM
    #61
    PoBoyTaco
    PoBoyTaco Member
    Brian
    09 2.4 AC 2WD
    Dog crate
    Definitely shaky. Western union splice all the way. Don’t be scared to use a soldering iron.
    culveremt likes this.
  2. May 24, 2020 at 12:54 PM
    #62
    rnngwlf
    rnngwlf Member
    Andrew
    San Diego
    2012 White Tacoma TRD Double Cab LB
    This was a great help! I know it’s a post from years ago - but had similar situation and followed pictures. Now my snug top is good to go! Thank you!
  3. Mar 25, 2021 at 8:43 AM
    #63
    Wpfc2010
    Wpfc2010 Member
    Will
    ‘17 Tacoma Offroad, 5’ bed, crew cab
    Quick question: trying to tap the brake light of the left wiring harness. Problem I’m having is my wires are blue, green and white. Which one should I tap into with the break light wire? I already have the other one grounded. Thanks in advance!
  4. Mar 29, 2021 at 1:57 PM
    #64
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    Blue = Stop
    Green = Marker
    White = Ground
    Wpfc2010[QUOTED] likes this.
  5. Mar 30, 2021 at 4:35 PM
    #65
    Wpfc2010
    Wpfc2010 Member
    Will
    @PhenixFord so to confirm, I splice the red wire from the 3rd brake Light into the blue wire and attach the black wire from the 3rd brake light to a screw on the housing for the ground? Or would you recommend splicing the black wire into the white ground wire from the taillight? Never done this before so I appreciate it.
  6. Mar 30, 2021 at 5:34 PM
    #66
    PhenixFord
    Randy
    Arkansas
    This is the best method. /\ /\ /\ :thumbsup:
  7. Jun 16, 2021 at 6:09 AM
    #67
    s.e.charles
    s.e.charles Well-Known Member
    has anyone tried this and were the results satisfying?
  8. Jun 29, 2021 at 9:16 AM
    #68
    Pigpen
    Dan
    Northwest Montana
    I haven't bothered
  9. Jun 29, 2021 at 11:27 AM
    #69
    dwong
    dwong Well-Known Member
    San Jose, CA
    '19 SR DCSB
    Puppyhunter has a great harness so that you don't have to tap into the oem brake light wiring. He was also able to make a harness to add a pop and lock for the shell if you have the OEM tailgate lock.
  10. Sep 26, 2021 at 1:17 PM
    #70
    Wpfc2010
    Wpfc2010 Member
    Will
    so you have a link for this. I had to rewire my brake light on my ARE shell as the stock light had water in it.
  11. Sep 26, 2021 at 1:31 PM
    #71
    dwong
    San Jose, CA
    '19 SR DCSB
    Send a PM to @Puppyhunter. He's a member on here and a wiring harness guru. He'll set you up!
  12. May 8, 2022 at 7:35 PM
    #72
    SeattleTacoma
    SeattleTacoma 2018 Tacoma TRD Offroad
    Brion
    Seattle, WA
    None yet, here to learn
    Great thread - I'll be wiring up my new (well, new to me) Leer canopy this weekend. Mine came with a fuse box (this one: https://truckoutfittersplus.com/Topper-Fuse-Box-Only.html). It has 2x4 prong connectors on top and the input on the bottom is a 6 prong. Because I bought it used, the 6 prong wasn't included with the canopy. In case anyone else is in a similar situation I found the replacement 6-prong wiring harness on Amazon (https://www.amazon.com/gp/product/B07DVM7KQP/) and here (https://truckoutfittersplus.com/tru...ss-only.html#product-details-tab-MyCustomTab6).
    Now with the excellent write-up here, it should be a pretty simple exercise to wire it up.
